I have a 2006 spec v, that I purchased 2 days ago, now I was trying it out yesterday and found out that I can't get into sixth gear! At all! Not even when the car is turned off. It's as if there is no 6th gear, but that's not possible? Any suggestions? Is it possible that something's blocking it? Is it possible the previous owner changed the gear box to 5 speed? Also the lock on reverse doesn't work either, meaning you can put it in reverse without the lock.
