Yahoo photos sucks @$$. Use Photobucket.
Tools needed:
Red loctite
5mm hex key
flathead screwdriver
pliers
10-12-17mm sockets and appropriate drivers and extensions
17mm wrench
patience
1. using 17mm socket and 17mm wrench, remove strut bar. No strut bar? Proceed to step 2.
2. remove upper intake section between MAF and TB.
3. using 5mm hex key, remover throttle body.
picture shows only top two bolts, there are two more underneath.
4. using pliers, remove hoses from upper manifold section.
Two are in picture, The other two are next to the throttle body, between the manifold and firewall.
5. using the 10 and 12 mm sockets w/ extensions, remove the bolts seen in these pictures:
Tools needed:
Red loctite
5mm hex key
pliers
17mm wrench
patience
