Hello folks,
Looks like, my 2006 Nissan Sentra 1.8S original battery is up for replacement. It died in 20 minutes when I left the headlights on by accident in the park. Since I do not want to get stuck in the freezing winter, I thought better change the battery.
The original battery does not state any specifications. Google wasn't much help either, so here I am with a few questions.
- What is the specification of this battery? i.e. what are cranking amps? From Autozone website, I figured, its mostly around 640 to 700Amps. There is one more Amp number that I could not figure out. Can someone clarify on this please?
- I checked the batteries at Costco and the similar spec battery, with group size 35, costs $68. Is it a good choice to go with, specifically for warranty purpose?
- As you see in the picture below, the J-hook screws are totally rusted and in pretty bad shape. I would like to use the new ones. Found following options, any preference?
http://www.walmart.com/ip/Everstart-966-10W-Everstart-10-J-Hook-Battery-Bolt/16006678
http://www.amazon.com/Taylor-Cable-21982-Battery-Hold-Down/dp/B000CPZZ6C
http://www.amazon.com/East-Penn-Batt-Hold-Down/dp/B001DKQQZE
http://www.amazon.com/C-NECTS-Rubber-Hold-Down-Kit-M051003/dp/B006PANFY2
- The videos I checked for battery replacement spray some stuff on these bolts to loosen up, what spray is it, especially around the battery terminals?
- Once you replace the battery, do you need to jump start it or you can start the car as it is?
- Finally, is there any auto parts store online that is amazon for auto parts (minor stuff like this, of course)
Thanks in advance.
Original Battery
Thanks in advance.
Original Battery
