i have an 03 spec and im wondering if an 02 will work the same? is there quality difference in them?
D dani_boi · Registered Joined Dec 30, 2007 · 344 Posts Discussion Starter · #1 · Aug 14, 2012 Only show this user i have an 03 spec and im wondering if an 02 will work the same? is there quality difference in them?
I i68k · Registered Joined Dec 14, 2006 · 2,679 Posts #2 · Aug 14, 2012 Only show this user the early 03 is the same as the 02 the late 03.5 has a different connector on it look at your wiring harness connector, or use your vin make sure you only use genuine nissan oem maf, or you may have more problems.
