I have the 14 inch wheels on my GXE but I want to get 16 inch wheels and also move up the overall diameter. Where would I go to get my speedometer calibrated to the new wheel diameter?
search the other messages on the board. I posted a table a while back about several alternative sizes and their effects on the speedo. Don't assume your current speedo reading is accurate either, you also need to calibrate your current setup to see if it is low or high. 60 mph indicated on my speedo is 57 mph actual.
Super Moderator
If the speedometer is digital (not driven by a cable), most likely the dealer.
Yup, the dealer...or any other place that has a dyno. I guess you can drive the car hooked up to the dyno and while the car is at a certain speed, put the needle on.
