All right! It's been now almost two weeks with my new Spec-V and I only have good comments. The mod process has already begun (mostly old GXE mod swap) and I will use this page to link from my sign (instead of having a 6 lines sign to kept the admin cool!)
This first post will be edited each time when a mod is added to the car.
General
http://public.fotki.com/angel2167882/se-r_spec-v_2003
¼ mile timeslip and vehicule mods
http://www.b15sentra.net/forums/member.php?&do=vehicledetails&userid=7494
Cosmetic and lightning modifications
Performance, handling and maintenance modifications
Audio modifications
Lots of things planned, so little money to spend on it. Wish me luck for my next years money sucker
Preview image - pickup at the dealer
General
- Car: Nissan Sentra SE-R Spec-V 2003 (canadian model)
- Color: Molten Silver (KY4)
- Package: Sport Package (same as US Audio Fanatic and Security package - ABS, Side air bag, Sunroof, Rockford Fosgate "Clarion" 300W audio system, anti-thieft, immobilizer)
- Date build: 10/02
- Date bought: 2003-05-09 (the last 2003 of the dealer)
- Where: Grenier Nissan
- Odo: 250Km (lots of road test on it)
- Introduction thread here
- 2003-05-09: LLumar black chrome window film tint, free from the dealership!
- 2003-05-09: www.b15sentra.net license plate frame (was on my GXE)
- 2003-05-11: The famous NO-DRL mod with switch HOW-TO (was done on my GXE)
- 2003-05-11: PIAA Xtreme White Plus 9007 headlight bulbs
- 2003-05-11: PIAA Ion Crystal H3 foglight bulbs - Pictures here from my GXE
- 2003-05-11: AERPRO inside 9" blue neons mounted on the C-Pillar HOW-TO (was on my GXE)
- 2003-05-19: Fog lights re-wire (to work without headlight and with the high beam)
- 2003-06-18: 3M Paint protection treatment
- 2003-07-06: Calipers painted with Dupli-Color High Temp Aluminium
- Planned next: Install my JDM Nissan sidemarkers
- 2003-05-19: K&N Filtercharger drop-in cleaned P/N: 33-2031-2 - The fit is PERFECT! (better than my GXE)
- 2003-05-19: "Air intake ghetto trick #2" - Bottom air intake resonator removed
- 2003-06-05: Mobil1 SuperSyn 5W-30 - First oil change done at 3500km and the engine did'nt burned a single drop yet
- 2003-06-24: Knock sensor relocalisation - Slight difference with the NPM: I wrap the knock sensor into a cotton clothe and zip tie it to one of the A/C lines
- 2003-06-30: A/C on defrost microswitch disable - Did done it while installing my new radio... so easy!
- 2003-07-30: Cwepruk's motor mount inserts - Launching the car is so easy now without the wheel hop!
- 2003-07-23: Hotshot header receive! Just waiting for the installation...
- 2003-08-13: Hotshot header installed - More performance and no more pre-cat failure... anything else to say?!
- 2003-08-19: Red Line MTL & MT-90 (30/70 blend) synthetic transmission gears oil - Done at 10000Km
- 2003-08-26: Ignition timing advanced with the Consult-II
- 2004-02-01: DMS crank pulley and Vibrant Performance muffler waiting for install!
- 2004-04-30: Custom exhaust with CherryBomb glasspack resonator and Vibrant muffler - Sound great!
- 2004-05-14: Front MMI fixed and alone now (rear MMI removed)
- 2004-06-29: Secondary runner butterfly screws check and threadlocked
- 2004-11-01: Redline MTL/MT-90 (70/30) mix, more suitable for winter
- 2004-11-15: Redline SI-1 and Water Wetter additives
- 2005-04-09: K&N Typhoon CAI installation
- 2005-04-21: Faktion Short-shifter bracket GenII (in french)
- 2005-10-01: Brembo front vented & rear solid discs, PBR Ultimate Ceramic pads, Motul 5.1 (in french)
- Planned next: Custom Hyperground kit
- Planned next: Stainless steel cat-back (custom or brandname)
Audio modifications
- 2003-05-19: Alpine SPR-174A Type R 6½ rear speakers (was on my GXE) - Wired to the OEM AF amp... so sound like crap (50% distortion at least) for now because the amp cannot drive the speakers loud enough
- 2003-06-30: Kenwood KDC-MP922 CD/MP3 headunit and OEM amp rewire - The setup is perfect and now my Alpine 6½ and the OEM sub play really well!!!
