1 - 15 of 15 Posts
Well let me put it to you this way... When the rest of Hurricanes Bonnie and Charlie made their way up here couple weeks ago I was really glad I had one on my nismo intake. I had ot drive up to JFK in NYC on Belt and uhh it was flooded, the engine would have definintelly sucked water in if not for the valve so uhh I think it's worth it seeing as huw much money it can save you in the long run on repairs.
I had an ingestion problem once. I had to replace my maf sensor and my plugs. a lot of trouble and alot more than 50 dollars so I think def they are well worth it.
Iknowyoulovereadingso..
still debating whether or not to buy the stupid bypass. i read on aem's website that they dont recommend the bypass valve because it changes the airflow inside the intake or something like that and have heard from members on the board that it can reduce the gains from the CAI. im lowered on progress springs, which isnt that low but then again new york does have its rain storms from time to time and i get scared drivin in them cuz i can barely see the road infront of me to dodge puddles. from what ive heard there has to be atleast a foot of water to submerge the filter. lets say roll into the "river" but dont accelerate until you clear it, will that help prevent hydrolock?
I really doubt you'd be able to make it across since water will pretty much stop you in a second... I rather be safe than sorry.
Bow to your SE GOD
That test is a load of crap. Look at the length of tubing they use, and how much vertical tubing there is! Our entire CAI's are shorter than just the vertical section of that thing- it's BS for normal cars.
I said I would'nt install a CAI on my car without one at first, but after installing it, the positioning of the thing makes it absolutely a waste- the only place to mount it is right before the MAF.
In real life, I honestly doubt it would save you, if you're in a position where it would be effective.
I took it off and sold it, and would much rather have the additional silicone coupler I do, than the BPV.
My $.02- Don't waste your money, and don't drive thru puddles.
1 - 15 of 15 Posts
