I have searched the forum about the R/F system getting a popping sound after a new h/u. Many people have said that 7551 is the correct wire harness for the the system because it can avoid double amping. (I don't know how it can avoid double amping because I still had to connect the amp from the new h/u to the aftermarket harness). I tried 7751 anyway, but I still got the popping sound when I change channel or source, and the volume is very low in the rear speakers. I basically connected every wire from the 7751 to the new h/u harness correctly except black/white (the amp ground), blue (power antenna), orange (illumination) because the new h/u does not have these wires.
I know there are many solutions such as bypass the stock amp using 7750, use a Speaker Level Converter or replace the stock amp etc.
The problem is I only want to replace the h/u not the amp, subs or speakers. How can I do that without having the popping sound?
Why doesn't 7751 work for my Pioneer h/u with the R/F system like other people claimed it would?
What exactly causes the speakers to pop when changing source?
Thanks!
Thanks!
