I have a 2004 Nissan Sentra 1.8L manual transmission that is giving me a headache.
Symptoms:
Let sit for 24 hours and car starts and runs for about 30 seconds and then dies. If you try to restart, it cranks fine, but will not start. If you then let it sit for 24 hours at least, it will repeat the 30 seconds run.
Completed work so far:
Check Spark - Spark is present
Check Fuel - Pressure was very low - Replaced Fuel Pump - Fuel pressure very good to the rail
Replaced the following items: Plugs, ignition coils, Cam Sensor, Crank Sensor, MAF, Throttle body, Throttle switch and ECM, Connector for CAM sensor wiring
If anyone can shed some light I would be a very grateful guy.
Thanks.
Old Car Guy
Crankshaft position sensor maybe? My power steering was leaking from the reservoir and it leaked on it and caused it to fail i cleaned it out with electronic cleaner and it worked fine just an idea i know this forum is a little old but ya never know
