I'm selling an 02 Sentra Spec V. The engine is all taken apart because there is a crack in cylinder 3. I don't have the proper means of fixing it. The guy who was fixing it discovered the crack but I don't have the time nor the money to get that fixed. The head has been resurfaced. The gasket is brand new, it comes with brand new piston rings, connecting rod bearing, timing chain, timing cover gasket set. The engine needs to be put back together after the block is either replaced or cylinder 3 is sleeved. Call/text 8476377525.
2900 OBO GUYS, the engine is already open, so it saves you the work of opening it!! The pix are the same as the other post!
