I have an '01 GXE 1.8 5-spd w/ 93k as my DD. Today, while running errands I parked the car and came back about 15 minutes later and it would not crank or anything. The idiots lights would not light up and nothing else happened when I turned the key - no clicking, buzzing, etc. It had been running normally before I shut it off.
I thought perhaps the clutch interlock switch had stuck as if you don't push the pedal all the way in it will do that (no start, no dash lights) I so reached under the dash and pushed the pin switch in - idiot lights would then come back on when I turned key to the start position but still no crank, no start, no nothing...
Tried to turn key again without resetting, no dash lights again so reset switch again with same result, idiot lights come on but nothing otherwise. After resetting when the dash lights come on and you try starting they dim a bit so there seems to be an electrical load being applied when turning the key. I also noticed when I tried to turn the key a few times today, the idiot lights would alternate between nothing, them being at normal brightness or them being very dim, just barely visible...
As its a few years old, I though perhaps the battery had an internal problem so I swapped in a known good battery (almost brand new, same group size, out of our other car) - exact same result as before so obviously not the battery.
Car is bone stock, no mods or aftermarket anything (like an alarm, radio, immobilizer). I've not had any issues of any kind with it recently and this problem has never occurred in the 3 years that I've had it.
Anyone have an idea what the problem is here?
