Will Putting Bigger rims mess up my Speedometer :confused:
C Chris20041.8 · Registered Joined Jul 22, 2004 · 14 Posts Discussion Starter • #1 • Aug 3, 2004 Will Putting Bigger rims mess up my Speedometer
Amplified2000 · Foolishly Impractical Joined Nov 7, 2003 · 966 Posts #2 • Aug 3, 2004 Not as long as the outer diameter is the same.... Basically with bigger rims you need thinner sidewall tires and everything should be ok.
