i'm about to get 15" volk te-37's for autocrossing and road racing. i would like to know if i should get 6.5 or 7" width. i would like to get the 6.5 for weight savings and cost. but would the 7 make a huge difference? or would the 6.5 be a very good rim to run on too. i will be running a 195 width tire for now until i seriously get into, which i will then change to 205 width tires. thanx
I think you might need to change the rim if you want to go larger. But I could be wrong. What I do know for a fact is that if you went with 215's (like myself) you will definately need 7" wide rims. I hope this helps you out a little...
OEWOKO, the 6.5" wheels will be fine for no more than a 205 tire. Whan you start to roadrace let me know where and when and I'll try to come out and support. There were a lot of jersey people at Watkins Glen last week so seeing you on track is a possibility. Later.
