1 - 20 of 34 Posts
hey, i have a rockford 801x powering 2 sets of rockford FNQs and the speakers are the best ive heard yet, but my problem is the amp overheats like a ****** and i figure if i can find a good 1000w 4 channel amp, thatll solve my problems, ( i know, way to state the obvious). i know that these speakers can handle 250 peak, and i doubt that an amp that says it will give that much wont put quite that much anyway. the FNQs are 100/200w, 4 ohm, 6.5" components. so that all being said, what is a good amp that fits the bill for all that crap i just wrote? any help would be appreciated, thanks!
the c2k4.0x, says 100x4 @4ohms, is that rms? are these amps very good/expensive??? im trying not to crush my bank with this... thanks with for your help!
King of OT
Yes, they are very very good, but very very expensive.....
ohhhh, is it that my gains could be too high??? the amp seems to shut off faster when i blast it...
Discussion Starter · #8 ·
haha, i guess so... thanks, i'll turn the gains down and see if that helps. that wont effect my volume will it?
NISMOnkey
It will. Your gains should be set so that at whatever gain setting you're at, your h/u volume will be at about 3/4 max before it starts to distort...
So if your gains are too high, you might be at ear-piercing sound at 50% volume, and so on.
Let us know how it goes.
Discussion Starter · #10 ·
ok, i turned them down, and i blasted it, and i didnt actually feel(hear) the need to turn them up at all, bit i did just a tweek. the funny thing is that my subs seem to have attenuated themselves to the change in my components...strange? thanks for your help guys!
-anthony
Discussion Starter · #11 ·
errr, attenuate was not the right word... i go to turn it up, and my subs arent working, so i said, "well, maybe i didnt attach the wires when i moved the box back." so i reattach the wires, ensure that they are working at minimal volume, and i go and turn it up, nothing. so i turn up everything i can to get them to work, and i go and look at them..... and i dont hear a thing, but they are flapping around like you would not believe!!! they were about as linear as(insert the most NON-LINEAR thing youve ever seen). WTF!!!!! im starting to get really pissed with this kinda crap. and to top it all off, my tweeters are scratching pretty bad off and on. what are good reliable amps/subs/ components that are prefferably not too expensive??? next month is my audio shopping month, now.
um, not fosgate
their amps are decent, but I would steer away from the rest. Although I have heard that a few of their subs sound ok, I don't have any experience though.
what kind of budget are you looking at first of all?
Basshead are you running an amp in tri-mode? Are you using passive X-overs or some sort of x-over on the amp? The full excursion with no output is a weird one.
I would double check all of the connections and the settings you changed. I have seen subs "flutter" when they are getting voltage and no signal.
Good luck.
Discussion Starter · #14 ·
well, whatever it was with the subs, i fixed it. as far as the components go, i want to keep them because they sound amazing. but that friggin amp overheats within an hour if i dont give it a break, and the higher the volume, the time seems to decrease almost exponentially.so, any good amps that wont cost me an arm and a leg>? i kinda need 100/[email protected] a little over that wont hurt.
King of OT
What;s your max price???
OT Whore
Funny, the amp at Best Buy is always overheating while pushing those pos subs to bottoming out nonstop while the idiots praise how awesome it sounds.
the 8004? I haven't been able to test it at best buy....last time I went in there a kid was there changing speakers every 2 seconds...has best buy ever sold the RF Power series? I don't think the 8004 is from that series if they even make it anymore...
1 - 20 of 34 Posts
