1 - 1 of 1 Posts
Does anyone know if you can swap a 1.6 engine to SR20VE VVL (both with standard transmissions) fairly easily?
Is it a drop in replapacement (minus the obvious: throttle body, computer, exhaust, shifter gate and add a hydraulic clutch that will have to be done.)?
I am wonding more specifically about whether I will have to swap or build engine mounts and what about the stearing knuckles?
Will they take the same driveshaft?
Are the physical dimensions basically the same?
I'm racing the car btw, not a street vehichle...I'm starting with a 97 200sx with a 1.6L engine.
1 - 1 of 1 Posts
