I have a 06 spec v none brembo I'm trying to figure out if I need to replace the brake lines because I am upgrading to the brembo calipers and also upgrading to slotted rotors
I'm not sure about the brake lines, I'd say get some you know will fit just to be safe though. You could probably find some cheap braided lines that'll work for like $50.
Also, as a heads up, the brembo equiped models don't have ABS, so you'll probably have to remove it from your car.
I have brembo and slotted disks on my 06 and i really like it. Smooth but firm.
Good luck.
