Over the past week my car has been idling weird from 1500 to 2000 rpm up and down when I put the car in neutral as I am braking to stop. Once I stop it goes down to a new idle at 1000 rpm. It seems to be getting worse and no MIL light is on. It's the 2.5 engine and it vibrates a little more than normal if I'm sitting, but this could be normal as it has 155k kms. Never had one problem til now.
I am planning on doing my first spark plug change and cleaning my K&N filter (8 months since last clean and 40k kms.) tomorrow to see if this helps, but can't see how.
yea, i would continue with your tuneup as planned, see if it helps. hope you check all your fluids, oil and coolant. these 2 common problems that usually cause rev jumping. one if your maf readings (clean or new maf), the other is your tps failing (new/reman throttle body). either way you will need to do an idle relearn to correct your idle jumping
Thanks for the reponses. Does Coolant really play a big role in the idle jumps?
Come to think of it it might as in the early mornings on my way to work (cooler outside) I have no idle issues, then in the afternoon leaving work (warmer outside) thats when I start seeing the jumping (especially when the motor is warmer).
As for the idle relearn, I took the steps from this forum and will try it tomorrow and see with all of the maintenance (spark plugs, etc.) I am doing.
Did the maintence on the car, cleaned the MAF sensor, cleaned the throttle valve, and now the MIL light just came on. Hooked up my computer to the car and it says the MAF sensor has low input...so this might be the problem finally!
Drove to work this morning and the MIL light is still on and the revs are twice as worse, almost like the car is trying to gasp for air. the idle is at 1,250 mow, not the 750 as suppost to be. This is even after the idle relearn. Going to pick up a new MAF sensor today and install it tonight. If this does not work I'm selling the car and buying something else besides a Nissan.
Changed the MAF sensor and the check engine light has not come back on yet...but it is still idling from 1500 to 2000 revs up and down constantly. Did the idle relearn and still did not fix it.
Dropping it off to Nissan dealership tomorrow as I do not know what else is left that is causing this problem.
Sounds like ur coils are going. They only last about 90k miles. But also check ur MAF and ur intake if its loose. A pedal dance/idle relearn will not hurt
Related Threads
B15 Sentra Forum
2.5M posts
41.1K members
Since 2000
A forum community dedicated to Nissan B15 Sentra owners and enthusiasts. Come join the discussion about troubleshooting, maintenance, reviews, modifications, classifieds, engine swaps, and more!
