Hello , I am a new member in search of some help with a 03 Sentra 1.8 ( w coil packs ) . When the car is cold and when 1st started the engine will surge and some times die . It will take several attempts to keep it running . After 1 - 2 minutes the idle will even out . If I allow the car to sit and come up to full temp it will drive fine . If I try and drive the car as soon as the idle stops surging the car has no power and surges and bucks . I can drive the car ( reaching full operating temp ) and the condition will not change . How ever if I stop and turn the car off and restart it it will run fine . What is changing when I turn the car off and restart it ? I just had a diagnostic done and have been told it needs a new timing chain .
Prior to the diagnostic the only codes that showed were 1147 = not reaching max voltage / 0139 sensor slow responce / 0340 cam position sensor . I cleaned the connector for the cam sensor and the 0340 has not returned . I have also replaced the post cat o2 sensor .
