Hello,
My ex's old 2002 SE-R Spec-V has been in my yard for a bit and I need to get it going. It turns over fine, and starts normally and the instantly stalls within 1-2 seconds. Giving it gas bogs it down and stalls even faster. RPMs drop, a quick studder then off.
I did already try disconnecting the MAF sensor and it did the same thing. The fuel pump turns on and you can hear it prime fine.
What should I look into next?
I'm having the same issue. I also have the p0300 code. I've just changed the o2 sensor, maf, injectors,fuelpump, sparkplugs, and coils before the sputtering and dying out. Some guy told me he had the same issue and changed the throttle body and it solved the problem. So I'm planning to get one. Lmk if u solve the problem.
