So I have the 1.8l 5speed and I found an 02 ser.. i was wonder how well the 02 ser stock rims would fit on my 01 sentra.. there 3 inchs bigger .. but does that even matter? And how rare are these 02 sers.. cause I'm transfering all of the interior seats, panels and such to my 01 sentra.. and front bumper and the rims to spruce up my 01
Most of the time it's going to be the spark plugs or coil packs that are the culprit. A misfire is the most common reason that your Nissan Sentra would be jerking while accelerating. ... Oil on the plugs, the wrong plug, or bad spark plugs can cause a misfire
carpet cleaning service
The two easiest ways are to check the sticker plate in your car, it should be located inside the driver side door, or look online for the vehicle specifications for your exact make and model. That should tell you the standard rim size.
www.manchesterdumpster.net
