No start on 1.8L 02 GXE - Page 2 - Nissan Sentra Forum - B15, B16 and B17 Sentra Forums
post #16 of 35 Old 04-14-2009, 04:08 PM Thread Starter
Subliminal
Quoted: 0 Post(s)
(Thread Starter)
I actually did not know that. The wide open throttle attempts on my part probably started at day 3 of the problem.
damon
Subliminal is offline
post #17 of 35 Old 04-14-2009, 04:19 PM
kbeezee
SE-R Fetish
Quoted: 0 Post(s)
Send a message via Yahoo to kbeezee
Yeah you cleared the raw fuel out of the cc by holding the throttle open... so maybe its a bad injector causing a misfire and when shut off its leaking fuel (injector seal?) But you should definitely have a code or two...
kbeezee is offline
post #18 of 35 Old 04-14-2009, 04:24 PM Thread Starter
Subliminal
Quoted: 0 Post(s)
(Thread Starter)
Approx 2.5 hrs before scanner arrives.
I'm like a kid on Christmas over here.
post #19 of 35 Old 04-14-2009, 05:43 PM
02 SPEC-Vicious
OTHER NEW ENGLAND B15'S?
Quoted: 0 Post(s)
Send a message via AIM to 02 SPEC-Vicious Send a message via Yahoo to 02 SPEC-Vicious
does your car have to perform a idle relearn procedure like in the specs?
02 SPEC-Vicious is offline
post #20 of 35 Old 04-14-2009, 05:54 PM
sentra728
Quoted: 0 Post(s)
Send a message via AIM to sentra728
Starter relay?
02 Blackout GXE - Sold
93 LX 5.0 - average 11 sec. DD
sentra728 is offline
post #21 of 35 Old 04-14-2009, 06:23 PM
speedjunkie
Quoted: 0 Post(s)
Send a message via AIM to speedjunkie Send a message via Yahoo to speedjunkie
Originally Posted by sentra728
Starter relay?
he has said many times the engine will turn over and that the plugs were fouled with fuel.
On a quest to prove everyone wrong on what they think they know about the QG18DE
Brand Spanking New Forum For Sentra GXE, XE, and 1.8S Owners just search google for qg18de and come join our forum
speedjunkie is offline
post #22 of 35 Old 04-14-2009, 10:16 PM
TechSalvager
Quoted: 0 Post(s)
Originally Posted by Subliminal
So, I cranked it and it fired right up today. Ran rough at first and smoked like a sonofabitch for a while. Not sure if its an issue with the smoke, or because i'd been dumping gas into it by holding down the pedal and trying to start it for a week.
Definitely running like crap, definitely has the check engine light on...
30 minute update: It will start and run every time, but it smokes and doesn't quite sound right and the CEL is on.
Of course, I gave my buddy back his scanner, and I don't trust it driving to Autozone in 5 oclock traffic.
Any thoughts?
PS - Just to butter you guys up a little bit,[butter]I've been coming to Nissan forums on and off for 3 or 4 years now and this one is by far and away the best one I've been to.[/buttering]
did you crank before or after you changed CPS if you changed it?
WWW . QG18DE . NET
TechSalvager is offline
post #23 of 35 Old 04-14-2009, 11:26 PM
02 SPEC-Vicious
Quoted: 0 Post(s)
say goodbye to your headgasket
post #24 of 35 Old 04-14-2009, 11:34 PM
speedjunkie
Quoted: 0 Post(s)
there is nothing in his post that I read that would indicate a blown or leaking headgasket
post #25 of 35 Old 04-14-2009, 11:39 PM
02 SPEC-Vicious
Quoted: 0 Post(s)
not an indicator of a head gasket issue?
post #26 of 35 Old 04-15-2009, 12:15 AM
TechSalvager
Quoted: 0 Post(s)
could be or could be because of extra fuel been dump before that.
Best to do compression check also.
WWW . QG18DE . NET
post #27 of 35 Old 04-15-2009, 01:06 AM
fluentsextra
Quoted: 0 Post(s)
+1 on the headgasket
fluentsextra is offline
post #28 of 35 Old 04-15-2009, 01:52 AM
breezynutz1458
Quoted: 0 Post(s)
most blown head gaskets don't smoke. is it blue or white smoke? It might be his rings too
breezynutz1458 is offline
post #29 of 35 Old 04-15-2009, 07:15 AM Thread Starter
Subliminal
Quoted: 0 Post(s)
(Thread Starter)
Well, I ran the codes and it came up with p0302, which is 'misfire detected in cylinder 2'.
Not as conclusive as I had hoped.
However, I think I know my next step:
I'm going to swap around the coil packs and see if the code changes to one of the other cylinders.
Thoughts?
post #30 of 35 Old 04-15-2009, 11:35 AM Thread Starter
Subliminal
Quoted: 0 Post(s)
(Thread Starter)
Ok, so I went to swap the coil packs and wouldn't you know it wouldn't start to set another code.
Pulled the rad cap and the level was low. Looked at the overflow bottle, also low. Pulled the dipstick, and she looked a little suspicious. I'm going to do a compression test later on, but it's looking more and more like the gasket.
Although I am pretty surprised that such a low power car, driven by my wife (not a heavy foot) blew a gasket.
But, what do I know?
Anyone have a good writeup on the 1.8l head gasket swap. The car hasn't been overheated (this much I know), so I don't think a mill is necessary, maybe just a new gasket and bolts.
On my ol' turbo dodge, I could swap gaskets in as little as 2 hours...this one looks a little tougher, though. ;-)
User Tag List
