B15sentra.net - Nissan Sentra Forum
B15Sentra.net is the premier Nissan Sentra forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average.
Old 11-22-2004, 02:56 PM   #1
SR20DE_MAN
Canyon junkie! ( ^o^) <3
SR20DE_MAN's Avatar
Send a message via AIM to SR20DE_MAN Send a message via MSN to SR20DE_MAN Send a message via Yahoo to SR20DE_MAN
Exclamation What fits my car? Wheel & tire size answers!
Welcome to the wheel & tire sticky. Everything that you need to know about wheels & tires can be found in here.
WHEEL ALIGNMENT WARNING: Before we start off, I'd like to remind everyone that if you have a 1995 & above Nissan Sentra or a 1999 & above Infiniti G20 that have a rear torsion beam, DO NOT PAY FOR A 4 WHEEL ALIGNMENT. The shop will be ripping you off. Unless the shop can physically bend the rear beam to change the toe, they can't do a single thing in the rear. They can only work on the front tires. This will be 99% of the shops that you go to. The rear beam is non-adjustable. It's fixed. There are only 2 people that I know of that can bend the rear beam: Darren at West End Alignment in Gardena, California & Steve Foltz that I believe is in Colorado. That's pretty much it. So remember, don't let the alignment shop charge you for a 4 wheel alignment. If you do, you will be giving them a very large tip.
WHEELS
Wheel offset: The lower the number, the farther the wheel sticks out of the wheel well. The higher the number, the farther the wheel goes into the wheel well. The Sentra came with different wheels, so the stock offsets will be listed for each Sentra model in THE FITMENTS below. Try to stay within 40 to 47mm as far as offsets go.
Bolt pattern: B15 Sentra cars use a 4x114.3 mm (4x4.5") bolt pattern. This is the most suckiest bolt pattern of all time. Wheel manufacturer's hate you guys. Why? Hardly anyone buys 4x114.3 wheels. Wheel selections suck in this bolt pattern.
Hub center bore (P.C.D.): B15 Sentra cars use a 66.1 mm hub center bore. Any wheel that you buy, MUST have at least a 66.1 mm or higher hub center bore. Anything larger than 66.1 might require a hub centric ring.
They center out the wheels properly. THEY DO NOT TAKE LOADS. The studs & lugs are the load takers. Keep in mind that if you autocross, road race, run canyons, & use plastic centering rings, they will melt with the heat of the brakes. I have used enough wheels without them & I pretty much don't use them anymore. If you raise the car in the air & tighten the wheels enough before putting it back on the ground, that will center out the wheel.
Brembo equipped SPEC V owners: You guys got the short end of the stick. Not only does the aftermarket suck for a 4x114.3 bolt pattern wheel, but having big brakes makes it even worse. It's not the offset that you're looking for. You need a wheels that have some well designed spokes to clear the brakes.
TIRES
Looking for 195/55-16 tires? Look no further. Here are some manufacturers.
Toyo Proxes T1R 195/55R16
Falken Ziex ZE-912 195/55R16
Ah yes! Now for the tire talk.
As a reference, shorter tires will rack up miles quicker on your odometer, but will increase acceleration. Taller tires save mileage on the odometer, but you lose acceleration slightly. If you stay close to the stock sizes, the difference is almost unnoticeable.
If you’re a handling junkie, you want a tire that has good grip & a stiff sidewall that doesn’t allow flexing. You should also try to match the tire to the rim by making it flush or stretching it just a tad bit like a 205/50-16 tire on a 16x8 wheel. Try not to bulge out the tire past the wheel. Width wins all the time.
If you’re a drag racer, you want a tire with good grip & a soft sidewall that will flex. Try to bulge out the tires a little past the wheel to get more flex. Get some super skinny wheels.
If you do not push your tires to the limit (i.e. autocrossing, road racing, canyon running, drag racing), any cheap tire will do for you. Another thing to remember is that you have to sacrifice one thing for another. There's no such thing as an ultra sticky, long lasting tire that performs well in the dry, snow, & rain. It ain't gonna happen. Sticky summer tires wear out quickly & usually don't do too well in the wet & you can forget about snow. All weather tires will last longer at the cost of losing a lot of dry grip, so if you plan on autocrossing, road racing, or doing any other spirited type of driving, you can forget about it, unless you had planned on sliding everywhere.
Ah yes!! Almost forgot one important thing: how to read a tire size.
215/45ZR17
OK! Using this as an example, the first number is the width of the tread. It’s 215mm wide. The next number after the slash is the height of the tire. You will get 45% from the 215mm width of the tire. So the height of the tire is 96.75mm tall. The letter after the 45 is the speed rating.
http://www.tirerack.com/tires/tirete...eral/speed.jsp
^ Go there to find out about the speed ratings & what they mean. The last number after the R is the size of the rim that it will go on. The 17 means that it goes on a 17” wheel.
One final thing. There is a tread width & a section width. The section width goes from sidewall to sidewall. You will notice that a 205/55-16 tire has about the same section width as a 215/45-17 tire (8.4”), but the tread width is thinner on the 205 & slightly wider on the 215. A 225/50-16 tire as a 9.2” section width & a 225/45-17 tire has an 8.9” section width, although both of them have the same tread width. The taller sidewall on the 16” tire causes the sidewall to flex out a bit. You have to keep the section widths in mind. These could get pretty wide & cause rubbing issues at full lock u-turns or on lowered cars in the rear.
I almost forgot! Tire pressure makes a huge difference in tire wear & gas mileage, so check your tire pressure!
THE FITMENTS
OK! Here’s the deal. This will be separated by QG18DE, SR20DE, & QR25DE cars. You see, each one has a different turning radius, so each one requires a different wheel offset & size.
http://www.rims-n-tires.com/rt_specs.jsp?postId=906
^ That will do wheel & tire sizes, offsets, & whatever else you can think of.
The following sizes are recommended to keep the speedometers & odometers at least 95% accurate. They're also sizes that can for the most part fit inside the wheel wells without much rubbing issues. If you lower the car too much, keep in mind that you might experience rubbing with some of the wider tires. Most of the rubbing will be in the rear fenders & some inside the front wheel well at full lock u-turns. If you decide to use any other wheel & tire sizes, you're going to have to do some further research on your own.
This is what I'm talking about when I refer to full lock u-turns & rubbing issues.
^ Yes. I'm partial to 16" wheels.
* NOTE: When it says 60 MPH = 59.9 or less, you will be racking up miles on your odemeter & you'll be traveling slower than you actually are. When it says 60 MPH = 60.1 MPH or more, you will be saving miles on your odometer & you'll be traveling faster than you actually are.
Starting with the QG18DE cars. They came with 3 wheel & tire sizes:
14” X 6” with a 45mm offset
185/65-14 (You can fit 205/60-14 on stock wheels. Taller tire.)
15” X 6” with a 45mm offset
195/60-15 (You can fit 205/55-15, shorter, on the stock wheel.)
16" X 6" with a 45mm offset
195/55-16 (The worst size ever. You can fit 205/50-16, shorter, or 205/55-16, taller, on stock wheels.)
Recommended wheel & tire sizes for 185/65-14 tire sized QG18DE cars:
15” X 6.5” or 7” (40 to 45 mm offset)
15" X 8" (38 to 40 mm offset)
195/55-15 (Almost perfect match. 60 MPH = 59.9 MPH)
205/50-15 (Slightly shorter than stock. 60 MPH = 59 MPH)
16” X 7” (40 to 45mm offset)
16" X 7.5" (40 to 45 mm offset)
16" X 8" (38 to 40 mm offset)
205/45-16 (Slightly shorter than stock. 60 MPH = 59.5 MPH)
215/45-16 (Slightly taller than stock. Not too many choices. 60 MPH = 60.4 MPH)
205/50-16 (Way taller than stock. 60 MPH = 61.5 MPH)
225/45-16 (Way taller than stock. 60 MPH = 61.3 MPH)
17” X 7” (40 to 45mm offset)
205/40-17 (Perfect match. Tires look like rubber bands on wheels. Potholes kill wheels. 60 MPH = 60 MPH)
215/40-17 (Slightly taller. Tires still look like rubber bands on wheels. Potholes kill wheels. 60 MPH = 60.8 MPH)
18” X 7” (40 to 45mm offset)
215/35-18 (Way taller than stock. Tires look like rubber bands on wheels. Potholes kill wheels. 60 MPH = 61.2 MPH)
205/40-18 (Way taller than stock. Tires look like rubber bands on wheels. Potholes kill wheels. 60 MPH = 62.5 MPH)
Recommended wheel & tire sizes for 195/60-15 tire sized QG18DE cars:
195/60-15 (Stock.)
205/55-15 (Slightly shorter than stock. 60 MPH = 59.2 MPH)
215/55-15 (Almost perfect match. Not too many tire choices. 60 MPH = 60.2 MPH)
16" X 8" (38 to 40 mm offest)
205/50-16 (Slightly shorter than stock. 60 MPH = 59.6 MPH)
215/50-16 (Slightly taller than stock. Not too many tire choices. 60 MPH = 60.6 MPH)
225/45-16 (Slightly shorter than stock. 60 MPH = 59.4 MPH)
17” X 7” (40 to 45mm offset.)
205/45-17 (Almost perfect match. 60 MPH = 60.1 MPH)
215/45-17 (Way taller than stock. 60 MPH = 61 MPH)
18” X 7” (40 to 45 mm offset)
205/40-18 (Slightly taller than stock. Tires look like rubber bands on wheels. Potholes kill wheels. 60 MPH = 60.6 MPH)
215/35-18 (Slightly shorter taller than stock. Tires look like rubber bands on wheels. Potholes kill wheels. 60 MPH = 59.3 MPH)
215/40-18 (Way taller than stock. Tires look like rubber bands on wheels. Potholes kill wheels. 60 MPH = 61.4 MPH)
Recommended wheel & tire sizes for the 195/55-16 tire sized QG18DE cars:
Don’t bother with a 15” wheel unless you know what you’re doing because you autocross, road race, or drag.
16” X 7.5” (40 to 45mm offset)
195/55-16 (Stock.)
205/50-16 (Slightly shorter than stock. 60 MPH = 59.1 MPH)
205/55-16 (Way taller than stock. 60 MPH = 61.1 MPH)
215/50-16 (Perfect match. Not enough tire choices. 60 MPH = 60 MPH)
225/45-16 (Way shorter than stock. 60 MPH = 58.8 MPH)
225/50-16 (Way taller than stock. WILL rub inside at full lock u-turn & you might need to roll the rear fenders. 60 MPH = 61 MPH)
17” X 7.5” (40 to 45mm offset)
205/45-17 (Slightly shorter than stock. 60 MPH = 59.6 MPH)
215/45-17 (Slightly taller than stock. 60 MPH = 60.4 MPH)
225/45-17 (Way taller than stock. 60 MPH = 61.3 MPH)
18” X 7.5” (40 to 45mm offset)
205/40-18 (Perfect match. Tires look like rubber bands on wheels. Potholes kill wheels. 60 MPH = 60 MPH)
215/40-18 (Slightly taller than stock. Tires look like rubber bands on wheels. Potholes kill wheels. 60 MPH = 60.8 MPH)
225/35-18 (Slightly shorter than stock. Tires look like rubber bands on wheels. Potholes kill wheels. 60 MPH = 59.4 MPH)
225/40-18 (Way taller than stock. Tires look like rubber bands on wheels. Potholes kill wheels. 60 MPH = 61.6 MPH)
Now the SR20DE cars! They came with 2 wheel & tire sizes:
16” X 6” with a 45 mm offset
Recommended wheel & tire sizes for the 195/60-15 tire sized SR20DE cars:
195/60-15 (Stock.)
17” X 7.5” (45mm offset)
17" X 8" (38 to 40 mm offset)
18” X 7.5” (45mm offset)
Recommended wheel & tire sizes for the 195/55-16 tire sized SR20DE cars:
195/55-16 (Stock.)
17” X 7” (40 to 47mm offset)
17” X 7.5” (45 to 47 offset)
18” X 7” (40 to 47mm offset)
18” X 7.5” (45 to 47mm offset)
Now the QR25DE cars! They came with 2 wheel & tire sizes:
17” X 7” with a 47mm offset
215/45-17 (You can also fit 205/45-17, shorter, or 225/45-17, taller, on the stock wheels.)
Recommended wheel & tire sizes for the 195/55-16 tire sized QR25DE cars:
195/55-16 (Stock.)
225/50-16 (Way taller than stock. Might rub inside at full lock u-turn & you might need to roll the rear fenders. 60 MPH = 61 MPH)
Recommended wheel & tire sizes for the 215/45-17 tire sized QR25DE cars:
16” X 7” (40 to 47 mm offset)
16” X 7.5” (45 to 47 mm offset)
205/55-16 (Slightly taller than stock. 60 MPH = 60.6 MPH)
215/50-16 (Slightly shorter than stock. Not too many tire choices. 60 MPH = 59.6 MPH)
225/45-16 (Way shorter than stock. 60 MPH = 58.4 MPH)
225/50-16 (Slightly taller than stock. Might rub at full lock u-turn & you might need to roll the rear fenders. 60 MPH = 60.6 MPH)
17” X 7” (40 to 47 mm offset)
17” X 7.5” (45 to 47 mm offset)
215/45-17 (Stock.)
205/50-17 (Way taller than stock. 60 MPH = 61.1 MPH.)
225/45-17 (Slightly taller than stock. 60 MPH = 60.9 MPH)
18” X 7”
205/40-18 (Slightly shorter than stock. Tires look like rubber bands on wheels. Potholes kill wheels. 60 MPH = 59.6 MPH)
215/40-18 (Slightly taller than stock. Tires look like rubber bands on wheels. Potholes kill wheels. 60 MPH = 60.4 MPH)
225/35-18 (Slightly shorter than stock. Tires look like rubber bands on wheels. Potholes kill wheels. 60 MPH = 59 MPH
225/40-18 (Way taller than stock. Tires look like rubber bands on wheels. Potholes kill wheels. 60 MPH = 61.1 MPH)
Any other sizes will throw off odometer readings by huge leaps. 18" wheels are not a good idea to run, but you can run them. As far as 19" wheels go, it's really not a good idea, but you can run them. Some 19" X 7" or 7.5" wheels with a 40 to 45mm offset and 215/35-19 tires would be the smallest to run. Now, if you do decide to run this size, you are asking for trouble. This is dangerous for the street because if you step on a crack, you will most likely bend the wheels. 20" wheels are even worse.
Keep in mind that these sizes are not set in stone. Some of you have certain applications (lots of camber, rolled fenders, etc.) & need special offsets & widths. You know what you're doing, so I don't need to elaborate further. For the rest of you, this wheel guide should have provided enough info for you to pick out your wheels & tires.
If you need any help on sizing, feel free to ask here. Some of you might want some really off the wall setups like 16x9 wheels & stuff. I can help you out with those off the wall sizes.
Happy driving!
Former 2000 Nissan Sentra SE owner. Now I drive a little & underpowered "girly" NA8C car that can own many big & overpowered "manly" cars on a good chunk of canyon roads & road courses. Go NA8C! \(^o^ ) <3
SR20DE_MAN is offline   Reply With Quote
Old 11-22-2004, 02:57 PM   #2
MN01GXE
Owner
Send a message via AIM to MN01GXE Send a message via MSN to MN01GXE Send a message via Yahoo to MN01GXE
STICKY!!! FAQ!!! Just somebody reward the effort with a lifetime of notoriety.
02 SE-R - Konig Traffiks w/ Azenis RT-615, Nismo FSB, Tanabe Sustec 4pt Brace, Nismo hard rubber bushings, Tarmaq RTB, //TMS CB, Injen CAI, fuel filler cap holder
01 GXE (autox #365) - 91.9whp - RIP 02/06/2007
MN01GXE is offline   Reply With Quote
Old 11-22-2004, 03:10 PM   #3
Black04SpecV
Black04SpecV's Avatar
Faq material... Great info!
Check out my Cardomain page! Link ---> 2004 SE-R SpecV T3/T4 powered
Black04SpecV is offline   Reply With Quote
Old 11-22-2004, 09:13 PM   #4
silversurfer
Southern Shift Racing
silversurfer's Avatar
Awesome write up!!!
Sticky this asap!
03 Silver SE-R V
6 DSP- 2007 CCR SCCA Champ
Southern-Shift Car Club
silversurfer is offline   Reply With Quote
Old 11-22-2004, 09:18 PM   #5
FuLIsh
Iknowyoulovereadingso..
Send a message via AIM to FuLIsh
wow very detailed and worth the read! this will probably be a sticky
Originally Posted by orangelloSE-R View Post
This kind of thing belongs in a prenuptial agreement. Autos FTL. If you can't keep your clutch, good luck keeping your balls.
FuLIsh is offline   Reply With Quote
Old 11-22-2004, 09:31 PM   #6
Original Mr Sentra
Original Mr Sentra's Avatar
Send a message via AIM to Original Mr Sentra Send a message via Yahoo to Original Mr Sentra
Very very good read!! Definitely needs to go into FAQ.
Turbo'ed B15 SE and 2009 Honda Fit Sport BSP 5AT
Another Potato STILL On The Way!
"Brembo, Bride, what's next?"
Original Mr Sentra is offline   Reply With Quote
Old 11-23-2004, 10:24 AM   #7
Squirrel Mafia
Push them off trees!
Wow! Everything that you could possibly need to know about wheel & tire sizes is here!
1994 Sentra SE-R (5-speed)
1999 Sentra SE-L (5-speed)
2001 Sentra SE-PP (5-speed)
2004 Sentra SE-R Spec V (6-speed)
2007 Sentra SE-R Spec V (6-speed) - Waiting to buy!
Squirrel Mafia is offline   Reply With Quote
Old 11-24-2004, 12:35 AM   #8
Zokambaa
I didn't see you mention the 205-60-15 size... I chose this mostly because no one was sure which size to get when I first got my car and everyone was saying the older style altima rims and tires fit fine.. so this is what I went with.. my dad's 97 altima has 15 inch rims with 205-60-15 size tires.
Spec-v Stock 215-45-17
sidewall 3.8 in
Radius 12.3 in
Diameter 24.6 in
Circumf 77.3 in
rev/mi 819.0
My winter tire 205-60-15
sidewall 4.8 in
Radius 12.3 in
Diameter 24.7 in
Circumf 77.6 in
rev/mi 817.0
With this setup the new winter tire the speedo readong is 0.3% too slow
When speedo reads 60mph acctual speed is 60.2mph
Never had a problem with the offset either I believe the altima uses 45.. but I'm not positive.. it doesn't rub anyway.
______________________________________________________________
Originally Posted by SR20DE_MAN
Ah yes. Too many of you have been wondering about what size wheel you can fit, what tire should you use, what’s your wheel bolt pattern, what’s your center bore, & other things like that.
Well! Today is your lucky day. I decided to make an ultra long post!
Ebony 2002 SE-R Spec-V Built: 04/10/01
Zokambaa is offline   Reply With Quote
Old 11-24-2004, 01:48 AM   #9
b0mberman
Bringin CA back
Send a message via AIM to b0mberman
Good ***** man! Very informative
2001 SE w/ Goodies
I'm so JDM, i walk on the left side of the hallway
Brought to you by shanno575
b0mberman is offline   Reply With Quote
Old 11-24-2004, 04:43 AM   #10
JoelAZ
M07S
I'm wondering why the 225/40/17 size was left out for the "for the 215/45-17 tire sized QR25DE cars"?
Joel
POST your AXE (Bass or Guitar) pics here!
Originally Posted by mrmixitup
The QR IS NOT a motor that was designed for N/A applications.
JoelAZ is offline   Reply With Quote
Old 11-24-2004, 04:58 AM   #11
TeknoPunk
Engaged! :)
sweet write-up Sticky!!!!
TeKnOpUnK
CURRENT: 1992 Acura Intergra LS
FOR SALE: 1992 Ford F-350 Crew Cab Duallie 7.3L Diesel
RETIRED: 03 SpecV
TeknoPunk is offline   Reply With Quote
Old 11-24-2004, 06:03 AM   #12
SR20dee
2busy4b15/but watch it
Send a message via AIM to SR20dee
NO sticky. but i will check out and update the faq's today ..
Flagged
GET INTO RACING!!!
www.ner.org www.nescc.org www.fcscc.com www.scca.org
01 Nissan Sentra w/PP(160K miles on the Shell)
95 Mazda B4000 LE (170k miles and beat to hell)
SR20dee is offline   Reply With Quote
Old 11-24-2004, 06:12 AM   #13
SR20dee
Looked at it again.. I may end up chopping it up and throwing it into the FAQ.. I know indeed that we did not cover aftermarket sizing But im sure most of this has been covered
GET INTO RACING!!!
Old 11-24-2004, 06:16 AM   #14
bjorkluv
Force Fed
bjorkluv's Avatar
Great Job!!! Matts just jealous he dint do this first
1995 Nissan RPS13 180SX
CliCk Here For PICS!!!
OR
CliCk Here For Action on YouTube!!
bjorkluv is offline   Reply With Quote
Old 11-24-2004, 06:25 AM   #15
SR20dee
Look at it this way.. if we have every thing stickied in technical. there will be no posts until page 2
GET INTO RACING!!!
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
