dash gurgling sound - B15sentra.net - Nissan Sentra Forum
Go Back   B15sentra.net - Nissan Sentra Forum > 2000-2006 B15 Nissan Sentra > General Discussion
Old 09-10-2004, 07:19 AM   #1
udelslayer
///N Power
Send a message via AIM to udelslayer
dash gurgling sound
I have an 03 V, 43K miles. Just recently, I've notices a sound from behind the dash that is heard from above idle to about 2000 rpms that sounds like a gurgling sound (like when there is air in the water system and its going through a heater core). My water level hasn't changed and nothing is running strangely, but it sounds like a small rodent trying to escape from under the dash just to the right of the gauge cluster. I installed the AC indiglo cluster layover last winter, but it doesnt appear to be scraping. Any suggestions or anyone ever heard of/heard this? I couldnt imagine anything mechanical behind the dash since most of that is electronic.
thanks
jw
JW
2k3 V : Uncorked + Horn mod
udelslayer is offline   Reply With Quote
Old 09-10-2004, 07:22 AM   #2
basshead
sonic perfection
hahaha, it may be the infamous foam snakes, the crappy insulation that nissan uses for our cars. they can make a scratchy noise, and dont be surprised if one comes flying out at you.
1.8l of AutoTragic Fury
Originally posted by AntonToo-
"if it gets you a blow job its functional in my book"
03 Blackout auto gxe -HKS E/ES-MMI/HS CAI
http://www.cardomain.com/memberpage/655016
Originally Posted by sje0123
JDM?? Riiiight. Good for you buddy.
I bet it has MaD VtEC yO1!!111 too right?
basshead is offline   Reply With Quote
Old 09-10-2004, 07:43 AM   #3
udelslayer
///N Power
I already had that after having the car for about a month, I had the defrost on full blast and this long arse foam insulator came flying out.
j
JW
Old 09-10-2004, 02:50 PM   #4
truraza
That must have freaked you out...I would have crapped or screamed...hell maybe crapped while screaming....
ttthhhpppppp......ARRRRRRRRRRRGGGHHHH!!
The trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.' - Ronald Reagan
I will keep my guns, ammo and money. You can keep your change.
truraza is offline   Reply With Quote
Old 09-10-2004, 02:54 PM   #5
truraza
Do you have the fresh air vent open or closed? Is anything on? I had this noise on my truck, it was a loose o-ring on the heater line.
Do you have an intake with possibly a loose fitting?
The part that gets me is the 0-2000RPM
Old 09-10-2004, 03:16 PM   #6
udelslayer
///N Power
The fresh air vent is open all the time unless I'm defrosting. Then I checked the lines going into the heater core, and they have pressure. Squeezing them I heard nothing. It just sounds like a jug of water sloshing around when I slightly rev it. It could be a loose o-ring, but I dont know if its anything at all.. it went away for today it seems. Nothing is running weird, I'm not losing water and there are no puddles or smells....
but that insulator snake did freak me out, that thing blows some hot air.
j
JW
Old 11-12-2007, 01:52 PM   #7
Spectic Tank
I'm bumping this thread because I'm getting this exact same noise and was wondering if anyone had more info on it?
BTW: I have an 03 Spec-V, 50k on the clock, and NO mods.
Spectic Tank is offline   Reply With Quote
Old 11-12-2007, 02:26 PM   #8
orangelloSE-R
geezinondowntheroad
orangelloSE-R's Avatar
Only thing i've read about that involved gurgling noises was a failing headgasket. You could PM truraza; he's on pretty regularly.
When you say "no mods", you mean "no mods except a header & loctiting the butterfly screwses" right?
2002 SE-R 5 speed
orangelloSE-R is offline   Reply With Quote
Old 11-12-2007, 02:31 PM   #9
Yossshi
Send a message via AIM to Yossshi Send a message via MSN to Yossshi
this is the funnest things i've ever read...fling foam snakes...i'd die laughing if i saw this happen
Originally Posted by mirrortints
Very true, if you find someone to give you a GREAT headjob, then you will be satisfied and go back to them FOREVER!!!!!
Yossshi is offline   Reply With Quote
Old 11-12-2007, 02:33 PM   #10
Spectic Tank
Nope, I mean "no mods".
After doing a little more research I'm thinking that it's air in the cooling system.
Old 11-12-2007, 02:37 PM   #11
orangelloSE-R
geezinondowntheroad
http://www.b15sentra.net/forums/showthread.php?t=135241 I suggest a kitten-free header.
It can be challenging to get that last lil bit of air out of the system; i think the throttle body is the high point. I bypassed mine; i don't feel the need to preheat my aircharge. Find a hill.
2002 SE-R 5 speed
Old 11-12-2007, 02:48 PM   #12
Spectic Tank
LOL, You and your damn persistence...we've had the header convo before:
http://www.b15sentra.net/forums/showthread.php?t=153581
I just popped the hood and noticed my coolant reservoir was below Min.. Know of any good hills?
Old 11-12-2007, 02:53 PM   #13
specvmike
LEMONade
Send a message via AIM to specvmike
Its air bubbles in your coolant. You might try "burping" the system. I had this same sound happening before my head gasket went out, at around the same mileage you are at Sucks man, hope thats not it. But at least its under warranty
2002 Blackout Spec V
specvmike is offline   Reply With Quote
Old 11-12-2007, 02:53 PM   #14
orangelloSE-R
geezinondowntheroad
LOLzes! Funny, i'm still advising the ounce of prevention.
When i said "find a hill", i meant it literally. Find a hill in the road or your driveway/parking lot & park nose up (the car) on it. If you get a good angle, you will make the radiator cap your cooling system's high spot. Let it run until it is warmed up & the air should go there. Try to find a hill by the mall, so you can goof off while it cools a bit. USE a TOWEL & CAUTION when opening the radiator to see if you got some empty space there. I'm sure somebody else has written up better engine burping directions.
FYI, the throttle body coolant bypass is very simple & might get you that extra 1/12th of a hp you've been wanting.
Headgaskets can be detected by getting an oil analysis from Blackstone Labs (cheap). You can also look for shiny stuff in the cylinder (pull plug 1st) or for floaty coolant in your oil, bad bad bad for teh bearings.
Good luck with it.
2002 SE-R 5 speed
Old 11-12-2007, 03:06 PM   #15
Spectic Tank
Good luck with it.
I appreciate it man!
I was being serious about the hill as well...i need to find a good one...lol.
I think I got it under control, I'm gonna "burp" the engine tonight.
If the headgasket was the problem would I be consuming oil as well? Right now my engine does not consume oil and never has.
