E-brake light on dash stays on - Nissan Sentra Forum - B15, B16 and B17 Sentra Forums
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average.
post #1 of 34 Old 01-24-2003, 06:52 AM Thread Starter
robaustin
Jersey Sentra
Quoted: 0 Post(s)
(Thread Starter)
ANyone have this problem? My Emergency brake light on the dash started staying on all the time about 2 weeks ago. I know the e-brake is off, IT's all the way down and the car drives just fine.
When it first happened it was right when we started to have the cold snap, but then it warmed up for a day or so and when the temp hit about 40 it seemed to stop happening. Now that we're in the middle of this deep freeze it's happening again. What would cause the light to stay on when the weather is extra cold. I wish it would warm up again so I can test my theory that it definitely has to do with the cold...
Anyone have any ideas?
I just don't feel like taking it to the dealer just yet because my dealer can't handle anything but routine oil changes and such on Saturdays, so I'd either have to take a half day (or day) off work to get it looked at.
--*Rob
2001 SE, Radium, PP, Sunroof, Rear Splash guards, Gas cap holder Mod
robaustin is offline
post #2 of 34 Old 01-24-2003, 07:22 AM
david
Fogey
Quoted: 0 Post(s)
Check your brake fluid level. I bet you its below the low mark.
b15 with a spud
g20 sporting b15 SE wheels 240k!!!
rusting NX track car with a replacement
i35 new daily driver
david is offline
post #3 of 34 Old 01-24-2003, 07:25 AM
RadiumJohn
Quoted: 0 Post(s)
The same thing happens to my car. After I drive for a while, it shuts off though. Maybe that's when the fluid warms up and expands a little. I don't know. I'm due for my 45000 mile checkup so I'll let the dealer know about it.
RadiumJohn is offline
post #4 of 34 Old 01-24-2003, 07:34 AM
jmihalchik98
SRT-4 God
Quoted: 0 Post(s)
that light is not just for the ebrake there duder , its also a warning light for your brake system (as mentioned ie: low fluid)
RED 04 SRT-4 12.97@107.3
SILVER 04 SRT-4 14.2@101.1 STOCK
formerly 02 ser 15.1@91
jmihalchik98 is offline
post #5 of 34 Old 01-24-2003, 07:54 AM
shortyb
Minister of A-Retention
Quoted: 0 Post(s)
Send a message via AIM to shortyb
As was stated, check the fluid first. Also check the cable and the area around the brake light switch. This was alittle sticky on my Xterra and when it got cold, the switch wouldn't function like it did when warm. Quick shot of some WD-40 and all was good.
" I woke up one morning and all my stuff had been stolen......and replaced with exact duplicates".- Steven Wright
shortyb is offline
post #6 of 34 Old 01-24-2003, 08:08 AM
david
Fogey
Quoted: 0 Post(s)
Trust me its the fluid. As for using your e-brake in the winter, you should try to stay away from that. Its just going to be bad news. Calipers tend to freeze up in the winter.
b15 with a spud
david is offline
post #7 of 34 Old 01-24-2003, 08:30 AM
wturri78
Not yer momma's Sentra!
Quoted: 0 Post(s)
I've noticed my rear brakes make a popping sound when I start driving, after leaving it parked in the cold with the parking brake on. No doubt the calipers are sticking...but how stable is a car that's just been left in a low gear, vs. using the e-brake? Anyone know at what point (either on a hill or from a push) it would start to roll?
'02 Spec V, Molten Silver
TWM SS and knob, 35% Tint, Black Leather Interior
CAI soon to come (weddings cost too much!)
wturri78 is offline
post #8 of 34 Old 01-24-2003, 08:37 AM
2000SR20
Quoted: 0 Post(s)
I NEVER use the parking brake on the car when it is parked, that is just begging for warped rotors. The car usually goes into first or reverse. As far as the car actually rolling forward/backward on a hill, have you ever tried to push the car when in gear? I doubt it'll go anywhere. Anyway, when you park on a hill you should always turn the tires towards the curb "just in case" the car moves, it'll stop against the curb.
2000 Nissan Sentra SE 2.0 w/PP - sold to JP
2007 Mercedes Benz R350 4MATIC - Kid Mobile
1991 Civic Si - 127.5HP/114.6ft-lbs - 1960lbs!! - AX/Track ho
2000SR20 is offline
post #9 of 34 Old 01-24-2003, 08:45 AM
6th-speed
SOPHROSYNE
Quoted: 0 Post(s)
I'm the lucky one to park a car in the garage but when I leave it outside for a day I tend to look for a flat spot and just leave the car in the 1st gear or reverse , hand brake ,winter and snow just don't go together
Cold facts about my NISSAN:Brakes lived for 63K miles ,engine replaced @ 62K miles
No respect or love for Nissan and QR25 from me.
Currently a happy owner of 2008 Honda Accord.
6th-speed is offline
post #10 of 34 Old 01-24-2003, 09:49 AM Thread Starter
robaustin
Jersey Sentra
Quoted: 0 Post(s)
(Thread Starter)
Ok, Car's going in next week for an oil change - they should be able to check the brake fluid as well I think. Sorry I'm a bit of a car ninny - can I check brake fluid myself and where at?
post #11 of 34 Old 01-24-2003, 10:04 AM
6th-speed
SOPHROSYNE
Quoted: 0 Post(s)
Smile
Take your car manual and read where it's located ,pop the hood (I'm sure you know how to do that ,if not there should be an instruction in the manual ) and see if it's below the mark , even if you don't know much about cars you should be able to complete that task
post #12 of 34 Old 01-24-2003, 11:32 AM
Sentra-volution
Quoted: 0 Post(s)
Our cars have an E-brake for a purpose. Use it or it will fail when you demand something of it. If they sit idle for extended periods, they seize up, and could stick ON when needed.
No, they won't cause warped rotors, unless you stood on the brakes then left the E-brake on right after.
Treat your cable like was mentioned to some lube, but I'd use lithium or white grease, not WD-40....that stuff tends to wash away.
2002 Sentra Spec V
Vibrant Blue (Best color IMO )
w/ Sport Package
The SENTRA Evolved!!!!
Sentra-volution is offline
post #13 of 34 Old 01-24-2003, 11:36 AM
SSJVegita
The NA Monster
Quoted: 0 Post(s)
how do u check if ur rotors are warped??? how would u know??
2006 Subaru Impreza WRX STI..........3rd gear turbo just kicked in yo!!
SSJVegita is offline
post #14 of 34 Old 01-24-2003, 11:39 AM
PhatVSpec
Quoted: 0 Post(s)
Send a message via AIM to PhatVSpec
Originally posted by SSJVegita
how do you check if your rotors are warped??? how would you know??
When u take the rim off sometimes its easy to see, when its bad. Another way is run your finger along the rotor and feel for uneven wear, you can deffinitly feel it, if it is.
My site, My Site if 1st link dont work
More Pics
Check it out!!
B15NJ- Anyone really interested in being an active member, pm me
http://www.B15NJ.net
Rocking a 2004 Accord EX-L with Navi
PhatVSpec is offline
post #15 of 34 Old 01-24-2003, 11:40 AM
6th-speed
SOPHROSYNE
Quoted: 0 Post(s)
well your inforamtion is somehow inncorect , the hand brake could cause the rotors to wrap if you pull it and leave it on after very hard braking ,
and to ask SSJVegita question you will feel vibration from your brake pedal under load and that could be a sign of a wrapped rotor
User Tag List
