The Damper Skinny - Page 5 - B15sentra.net - Nissan Sentra Forum
Thread Tools Rating: Thread Rating: 9 votes, 4.11 average.
Old 08-11-2003, 09:47 AM   #61
CowboyDren
Simian Rex
Send a message via ICQ to CowboyDren Send a message via AIM to CowboyDren Send a message via Yahoo to CowboyDren
You're mostly right, though I can't comment on where the piston sits when the suspension is under static load. I can say, however, that my SE/PP has about 2.5" of droop travel from static load, and probably about the same compression travel...stock.
The only way to downgrade springs is to take a Spec or a PP and install XE or GXE springs. Just about any other spring (except for the obsolete Pro Kits) are still heavier than a Spec spring. The lighter the aftermarket spring, though, the longer your dampers will last (thermal fatique).
Don't worry about the bumpstops too much; they're pretty durable. A good alternative would be Koni or ES polycell bumpstops if you're feeling paranoid.
-=|JP|=-
"I can tell you all day long that my dick is 25% stiffer than yours, but without 'hard' numbers or independent testing, who's going to know?"
CowboyDren is offline   Reply With Quote
Old 08-11-2003, 10:36 AM   #62
Sykikchimp
I'm more concerned that hitting the bumpstops during cornering loads will cause unpredictable handling characteristics, since bumpstops basically make your spring rates go up infinitly. Obviously not a good situation. With modern suspension technology, you shouldn't have to ever have to hit your bumpstops, IMO.
Maybe those uppermounts I saw in another thread, that allow for more compression travel, would help the situation...
I kinda wish someone made a little longer spring, or maybe even one that was the same length as stock, but stiffer.
Maybe a set of Ground Control coilovers with Linear rate springs.. I could preload the spring, and allow for more suspension travel that way.. (do they even make GC's for the spec-v?)
Sykikchimp is offline   Reply With Quote
Old 08-12-2003, 12:37 PM   #63
CowboyDren
Simian Rex
Originally posted by IO_SpecV_DeV
I find it interesting that no one has commented on the Tein S-Type springs. They give a mild drop while lessening the spring rate by a good amount.
ACK! I just got back from the Tein web site, and these springs SUCK! I'm sure they ride nicer, but they will only hurt handling. The front rate is just about stock, and the rear rate is significantly LOWER than stock (nearly 50lb/in). They'll lower your center of gravity, but you'll be riding on the bumpstops half the time anyway, and won't be able to enjoy it...
-=|JP|=-
Old 08-12-2003, 12:43 PM   #64
CowboyDren
Simian Rex
[QUOTE]Originally posted by Sykikchimp
Right, but without relocating the upper mount or shortening the rod, a lowering spring makes this a fact of life.
I'm talking to somebody who knows about this stuff now. The outlook is not sunny, especially if you don't like the idea of cutting holes in your strut tower.
Why? Spec-Vs are already underdamped and faster than most previous-generation SE-Rs that have been heavily modified. The Spec's weakness isn't rate, it's control.
Yes, they do. IIRC, the rate is something like 300 even (F&R), which is still an excellent configuration, as long as you're not using OEM dampers. For rates this high, you definitely want Koni inserts.
I'd be pretty happy with 200/300 (~50lb/in higher than a Spec-V) springs with long coils to avoid coil bind. Again, Konis will be necessary, and relocating the front strut mount +2" would help oodles. Maybe Scott can work that out...
-=|JP|=-
Old 12-16-2008, 02:44 PM   #65
nadrusik
Awsome
nadrusik is offline   Reply With Quote
Old 12-16-2008, 02:48 PM   #66
txspeccer
Originally Posted by nadrusik
Awsome
Silly Canuck.
Originally Posted by Fireman0605 View Post
oh B15sentra Banned Me For No Reason Again And Its Ok Wit Me Because I Guess I Got To Be White In Order To Be Like And Talk Like Im White Too. u have the very lack of KNOWDELGE. So get cha mind right FOOLS...
txspeccer is offline   Reply With Quote
Old 04-04-2009, 06:13 PM   #67
dirtyred
The book has been written. I post it everywhere I can cuz this site is great.
http://farnorthracing.com/autocross_secrets.html
Shiftboots, E-Brake Covers, Pillar Wraps, other interior Work.
The ONLY Supplier of Bride Shift boots
www.mIIIdesigns.com
dirtyred is offline   Reply With Quote
Old 08-09-2009, 03:37 PM   #68
psychoticSER
couldn't you have said something like 'push and pull cycles' or 'spring bounces' instead of oscillations? reading that word brings back headaches... from physics and digital logic... oww
psychoticSER is offline   Reply With Quote
Old 10-28-2011, 12:05 PM   #69
tredragon
Now I have two boys!
Send a message via AIM to tredragon Send a message via Yahoo to tredragon
Blast from the past. /
Two awesome sons, car on serious hold. Need stock interior parts (plastic pieces around window switches and door pullers), cheap/stock 4x114.3 wheels (16" pref). Email me.
tredragon is offline   Reply With Quote
