belt tensioner - B15sentra.net - Nissan Sentra Forum
Old 01-22-2013, 11:00 AM   #1
garywayne123
belt tensioner
02 spec v... working on changing my manifold, where is the belt tensioner on this car...lol i got the belt off by removing the altenator but getting on is alot more challenging... there has got to be a better way
garywayne123 is offline   Reply With Quote
Old 01-22-2013, 12:55 PM   #2
i68k
you should be using the auto-tensioner, its very easy to use. you should definately be removing the belt, before you remove the alternator, you dont want to strip bolts or bend stuff.
youre welcome to use the fsm, or the 'search' button in the menubar
here's the how-to you are looking for:
http://www.b15sentra.net/forums/showthread.php?t=186772
Old 01-22-2013, 08:33 PM   #3
garywayne123
funny i just put the bottom bolt into the altenator and forced the belt into place and puched it up to the last bolt...worked!!!!
Old 01-22-2013, 08:34 PM   #4
garywayne123
and yes the belt is around all of the pulleys
Old 01-23-2013, 12:04 PM   #5
i68k
you can use like a long crowbar or something as well, to lift the alternator with the belt on it to put in the top bolt. just a lot easier to turn the autotensioner and put the belt on, i lean my wrench on my oil filter, which holds the tensioner, and just put the belt back on. just takes a few times, and itll be easy.
Old 01-23-2013, 11:06 PM   #6
ten-sec Spec
The Black Cloud
Garage
yea honestly the belt tensioner in the spec sucks in so many ways whoever designed it that way was a jerk.
ten-sec Spec is offline   Reply With Quote
Old 01-24-2013, 05:46 AM   #7
txspeccer
Re: belt tensioner
Huh? It's a similar design as many other cars. Neither complicated nor difficult to manipulate.
Originally Posted by Fireman0605 View Post
oh B15sentra Banned Me For No Reason Again And Its Ok Wit Me Because I Guess I Got To Be White In Order To Be Like And Talk Like Im White Too. u have the very lack of KNOWDELGE. So get cha mind right FOOLS...
txspeccer is offline   Reply With Quote
Old 01-24-2013, 11:58 AM   #8
i68k
what ^^^ he said, its very easy once you know where it, which way to turn it, what size socket/wrench you need, etc. the hardest thing is taking the damn plastics off, lol.
Old 01-24-2013, 05:37 PM   #9
ten-sec Spec
The Black Cloud
Garage
lol i hate the belt tensioner it's just in such an awkward location i dont take the plastics off i always go at it from above because im too lazy to take off the plastics.
edit: and now that i really think about it i do more work that way anyway because i have to take out the overflow reservoir... LMAO
