Installing aftermarket amplifier subwoofer and headunit - B15sentra.net - Nissan Sentra Forum
Go Back   B15sentra.net - Nissan Sentra Forum > 2000-2006 B15 Nissan Sentra > Modifications - Audio
Old 01-20-2013, 11:50 AM   #1
Pyraxx
Is there a guide for what this guy was trying to do http://www.b15sentra.net/forums/show...ine+converter? If wanted a new headunit would it be possible to use a line out converter still? Also My brother has an old nissan maxima 96 with a Sony cdx gt56ui headunit. Does anyone know if i would just be able to use its wiring harness in my 06 sentra 1.8s with the rockford fosgate package?
Pyraxx is offline   Reply With Quote
Old 01-20-2013, 01:09 PM   #2
i68k
well, if you want to install all 3, or change any 1, there are wire harnesses available, except for the subwoofer, which you can custom wire into an aftermarket amp.
once you add an aftermarket head unit, you have control capability for an aftermarket amp. if you want to use the stock amp and sub, you can do that too, just by wiring in your headunit, im not sure but i dont think the wires from an old maxima will be the same.
i did add a headunit, with the stock amp and sub, as the headunit failed. then the amp failed a couple years later, so i had an aftermaket radio and aftermarket amp powering the stock sub, which i wired in. now i just use the 6 speakers with no amp or subs
Old 01-20-2013, 01:52 PM   #3
Pyraxx
when installing the headunit did you have to use this http://compare.ebay.com/like/1210139...Types&var=sbar
Old 01-20-2013, 07:16 PM   #4
i68k
yes, that is similar to what im using. you will need a face plate trim, obviously, and the 2 harnesses is what i used just for the headunit. there are other harnesses, i know some have rca on them. if you plan on using the stock amp and stock sub, it looks like you have the right wires, im not exactly sure about which harness to use. make sure you solder in your harness.
Old 01-20-2013, 11:01 PM   #5
Pyraxx
Ok so if I didn't want to use the prexisting amp could take the two harnesses out of it and splice together the wires for the speakers? Also if i get a new headunit what type of harness would i need to keep the prexisting sub connected so i can splice a line out converter to it instead of having to wire rca's all the way up to my headunit
Also do you have a diagram showing which color wire is what? Or at least know which one is the remote turn on wire that I will need for my new amp?
Old 01-21-2013, 08:22 AM   #6
i68k
if you want to remove, not replace, the stock amp, you will need to do some rewiring, as the thicker gauge speaker wire for the speakers are coming out of the stock amp. remember, the stock amp powers all the speakers not just the sub, otherwise youll need to rewire your speakers.
if youre using the stock amp, with an aftermarket headunit, i think you have the wires already. there are a few different harnesses without rca, there is also an amp harness, which you may need if you dont have the correct headunit harness.
to use the stock sub, with an aftermarket amp, you just wire it in to your new amp, not 1000w, it will blow the sub. there are no harnesses i know of to utilize the stock sub, but it is easily rewired.
im getting confused here, do you want an amp to power a sub, or do you want an amp to power all the speakers like stock setup, or do you want 2 amps? the stock setup is already wired into 4 channels, including the sub. your remote turnon wire is blue, you can find the stock wire diagram in the fsm, just look for premium audio setup, youll see the sub in the wire diagram.
Old 01-21-2013, 09:55 AM   #7
Pyraxx
Sorry I was just wondering how easy would it be to just have the stock amp removed and rewire everything. But basically what I am trying to do is install a new headunit and splice the subs wiring in the trunk with a line output converter. I want to avoid having to wire a remote turn on wire and RCA cables from the trunk all the way up to my new headunit and only want to worry about wiring my power wire from the trunk to my battery. And since the prexisting amp already has a remote turn on wire in it i was going to do like a 3 way splice i guess and wire it to my new amp while still keeping it connected to the preexisting amp. So in the end I want to keep my prexisting amp for the other speakers and dont care if the preexisting subs work and was just wondering if there is a harness that has the subs wiring in it.
sorry if i still sound stupid
Old 01-21-2013, 02:37 PM   #8
i68k
well, if you remove the stock amp, for your new headunit, you will need to rewire all of your speakers. however, if you plan on using an amp to power all the speakers, sub or not, all the wires going to the speakers are under the rear deck where the amp is. so if you were replacing your stock amp with an aftermarket, all the larger gauge speaker wires are already in the trunk, meaning they all run from the trunk to each corner speakers. in this case, you would just need to wire in your headunit to the amp, and splice the speaker wires into your new amp. it is your option to include the sub with this amp, as its already wired into both rear corners, or if your headunit supports, you can use a seperate amp to power the sub to control both amps, or rca them together.
not sure why you need an output after your sub.....? you only need the line output converter if your using rca from the headunit harness. if you use your aftermarket headunit, which should have rca on them, you just run the rca to the amp, and wire in the head unit, and youre good to go.
it doesnt matter, you will need to add an amp turn-on wire if youre using an aftermarket amp. normally you can follow your rca with the remote turn on, these wires should be opposite side of car as your power wire.
from my understanding, you want the stock amp to power all the speakers, which it already does. so you can just wire in your headunit harnesses. however, if you want to add another amp, you will need to wire in, or double, the amp turn-on for the aftermarket amp, and plug the rca for the aftermarket amp into the headunit itself, not the harness with rca. if you want it to power the stock sub, just cut the wires and wire them into the new amp if youre not adding a new sub.
the sub is already wired into your preexisting setup, it is part left rear, and right rear corners. there is no premade harness for this, the sub only has 4 wires, follow the wires back to the stock amp, cut them, and wire them into your new amp. all the wires are different colors, you can find the color codes in the fsm.
Old 01-21-2013, 02:57 PM   #9
Pyraxx
So your saying that taking the remote turn on wire that is already going to the stock amp and 3 way splicing it to power the new amp and still the stock amp at the same time will not work? If so elaborate on what you mean by doubling up the amp turn on
Old 01-21-2013, 05:58 PM   #10
i68k
no, im saying you will have to if youre going to ADD an amplifier with your stock amp. i mean doubling wires, putting a 3 way connection, so all your amps turn on with that one turnon wire. your headunit will need to turn both amps on and off, using that one blue wire.
