| Register | Home | Forum | Active Topics | Parts Catalog | FAQ | Garage | Photo Gallery | Search | Today's Posts | Mark Forums Read | Auto Escrow | Auto Loans | Insurance |
Thread Tools | Rate Thread |
#1 |
help!!
Ok so i have an 04 spec v and the engine went at 70k miles. Now that ive started working on it I've noticed that when i turn the radio on only the drivers side speakers work. It has a stock radio and all speakers are stock. So not a worrying issue i don't think. Ideas any one
| Sponsored Links | |||
Advertisement | |||
#2 |
its hard to say, the factory headunit are known for failure, but not to say it isnt a bad amp or loose wire somewhere. how does your cd/aux sound? does it act the same? does the rear deck speakers work? the subwoofer? use fade/balance to figure out what speakers are working. the tweeter and door speaker are parallel.
Aztec 02 Nissan Sentra SE-R Spec V, 270k miles blown head gasket @153k, original clutch! mods: optima, foglite mod, disabled auto a/c, dril/slot, es mmi's, jwt bsr, maf w/filter, catless header, ebay n1 catback, alum radiator, s.drives http://imageshack.us/photo/my-images/708/p1010008s.jpg/ |
#3 |
I did all the fade and balance checks.and i looked at all wires and fuses. I'm thinking the unit is fried so putting a new one in tomorrow
#4 |
awesome, make sure you solder the wire harnesses together, so you dont get static.
#5 |
Will do thanks for the tip. Also know of where to find the trunk carpet piece by any chance the owner before me took it out to "cut weight" and i can't find out anywhere
#6 |
you can order one directly from nissan, or nissan replacement parts website. you might get lucky if you search the classified, youre even more lucky if you find one in the junk yard
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Rate This Thread | |
