Thread Tools | Rate Thread |
#1 |
This post is also related to the Scanner "Connection Error" post that I put up but I didn't want to weigh down the post by putting everything together. Trying to keep it short and to the point.
So where things are right now is that the car wont start, I've replaced the crankshaft sensor (tested the old one, it had 1.2kila ohms between pins, FSM says it should be 0 or infinite), checked for fuel delivery (all good), timing chain sounds fine, checked for cylinder compression (all good), went to check spark.. NO good on all four coil packs (coil over plugs (COPs) and spark plugs were all replaced less than a year ago). Any thoughts as to what I could test next to see if what's preventing me from getting spark would be greatly appreciated!!!
| Sponsored Links | |||
Advertisement | |||
#2 |
Check ur fuses
Sent from my Autoguide iPhone app |
#3 |
Spec V Oddity
I had a similar problem before, car would only crank, ended up being my maf sensor, try turning on the car with the maf being unplugged, see if that makes a difference.
02 Molten Silver, B15 SE-R Spec V 91 Pearl White, S13 Fastback |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Rate This Thread | |
