Custom ac line for 1.8s b15 - B15sentra.net - Nissan Sentra Forum
Old 04-28-2012, 11:11 PM   #1
SeRReAL
I was wondering if there is a way to reroute or have a shop custom make an ac line for a 1.8s b15 and if there is a way to remove the ac line because i couldnt find anyway of removing it as it goes straight into the firewall any input helps
SeRReAL is offline   Reply With Quote
Old 04-29-2012, 07:52 PM   #2
i68k
did you check the fsm? you can download it for free around here somewhere
Old 04-30-2012, 07:59 AM   #3
JudoJohn
If you remove an AC line, you will need to evacuate the system first. the lines are under pressure and you need to be careful so that you don't get injured, too.
check with a local AC shop.
JudoJohn is offline   Reply With Quote
Old 04-30-2012, 06:51 PM   #4
SeRReAL
yes im aware of doing a recovery evacuate on the ac lines forgot to mention that earlier lol
