Prothane mounts on a QG. - B15sentra.net - Nissan Sentra Forum
Old 04-23-2012, 03:16 PM   #1
Christian87n
Question Prothane mounts on a QG.
Hey all,
I've been reading different things about these mounts for the QG. Has anyone used them before? What mounts will fit the QG? The last two things that I read was that the front mount from a QR is the same as the front and rear mounts from a QG. I also heard that the QG mounts are the same as the SR mounts. Can anyone confirm this? My OEM mounts are trashed and are in need of replacement. Thanks!
Christian87n is offline   Reply With Quote
Old 04-24-2012, 10:20 AM   #2
B15pwr
Garage
Just buy the oem mounts and if you want perfomance also get some motor mount inserts although it will make things a lot more shaky when you're holding the steering wheel but a big big big significant difference in handling and speed
B15pwr is offline   Reply With Quote
Old 04-24-2012, 03:16 PM   #3
Christian87n
I'm familiar with the increased vibrations, and I'm also familiar with the ES mounts coming off after a while. That's why I wanted the Prothane mounts. It seems that I may have to go down that route...
Old 04-24-2012, 03:50 PM   #4
B15pwr
Garage
Possibly
It's cheaper and if you do have to end up replacing them they aren't that exspensive of a replacement part
Old 04-24-2012, 06:02 PM   #5
Christian87n
Well, Prothane mounts aren't expensive at all, and I have access to a hydraulic press. I just don't want to get a mount that won't fit. lol
Old 04-30-2012, 06:11 PM   #6
Extreme
i've attached an image below which shows prothane part#14504 being used for the rear mount on a qg crossmember. the front uses the exact same insert, however i am still running the standard front mount to try and reduce the vibrations...
Extreme is offline   Reply With Quote
Old 05-01-2012, 05:28 PM   #7
Christian87n
Appreciate the picture!
Excellent, just what I wanted to see. Not that I will mind much, but how are the vibrations?
