Alternator whine problem - B15sentra.net - Nissan Sentra Forum
Go Back   B15sentra.net - Nissan Sentra Forum > 2000-2006 B15 Nissan Sentra > Modifications - Audio
Old 04-22-2012, 07:27 PM   #1
brigsbah
I know this sounds bad and isnt worthy of a thread, but heres my problem. I was working on the problem to fix it (only coming from the left rear speaker), and it seemed to me that I had fixed it. Then I realized that I wasnt getting and sound from the rear speakers at all.
After rigging it to where all speakers are working, the alternator whine went from the left rear speaker to the right front speaker???? Does anyone know what the hell happened and why it is coming from only 1 speaker?
brigsbah is offline   Reply With Quote
Old 04-24-2012, 08:35 AM   #2
i68k
are you getting speaker whine or alternator whine?
this is bad, is worthy of a thread, however, threads have been made for both occurences. have you searched thru all the threads?
check the battery terminals and grounds for tightness, and good connection. check the battery voltage motor on&off. check for other bad grounds or bad connections to your speakers.
Old 04-25-2012, 12:04 AM   #3
audio1der
Bow to your SE GOD
Only from one speaker off an amp powering more than the one? That's a new one. Make sure your power and signal wires don't go down the same of the car, make any points where they cross 90*, blah blah. Or just add an inline ground loop isolator, available anywhere. IF they're powered by your deck, I've got no clue but unhook them and turn up the bass
'01 SE wP/P 5spd.
Tein SS w/B15MS rear mounts, Nismo RSB, timing @ 19*, Magnaflow 2.25", ES shifter/RTA bushings, over-filled mm's, Techna-Fit SS lines w/Motul 5.1, HPS pads, Falken 912's on powdercoated 16's, dual batts, Boston Acoustics, Audioque, Silver Flute, Alpine and Phoenix Gold ICE
audio1der is offline   Reply With Quote
Old 04-25-2012, 07:24 PM   #4
RadioBoy
No Disassemble!
RadioBoy's Avatar
Yeah, typically whine indicates a grounding problem.
'04 Spec V, Bone Stock ~ Except for all the stuff I've done to it.
RadioBoy is offline   Reply With Quote
