Thread Tools | Rate Thread |
#1 |
Car keeps stalling
Car starts fine, runs for a minute, runs rough for a second and then stalls. Sounds like a fuel delivery problem. What do you think?
| Sponsored Links | |||
Advertisement | |||
#2 |
what codes are you getting?
#3 |
you need to pull the codes, got new cps? clean the maf? checked your oil and coolant levels? did an idle relearn?
#4 |
I'll check everything and get back to you..
#5 |
I have an '04 Spec V with a similar stalling issue.
On start-up the car idles and within a few seconds the tach drops to 0 and either the idle bumps back up or stalls. I cleaned the MAF with MAF electrical cleaner, let it dry(important), and so far the issue has not re-occurred! I'm running a K&N air filter and suspect the oil ended up covering the MAF. Good luck. |
#6 |
you need a new crank sensor, or you have wiring issues from the crank sensor to the ecu.
#7 | |
Cleaning the MAF only helped on a temporary basis. -Changed the Crank sensor - it did not help. -Changed the cam sensor - it did not help. Finally swapped the drive by wire Throtle body...so far no issues. |
#8 |
Start pulling sensors out one by one. If the car runs the same with the sensor plugged in as it does when you pull it out, then it's that sensor.
#9 | |
Fixed! |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Rate This Thread | |
