Reverse lockout? - B15sentra.net - Nissan Sentra Forum
Go Back   B15sentra.net - Nissan Sentra Forum > 2002 - 2006 SE-R & SPEC-V Section > General Discussion
Old 09-20-2011, 09:52 AM   #1
Hoff
Reverse lockout?
Did these cars come with one? If so, how it it activated? I've never driven another Spec-V and I bought my car somewhat disassembled. Now that I've got it back on the road this seems like a glaring omission if the car came that way. I have to be very careful on the 4-5 shift not to push the shifter over into the top of the reverse gate. The shifter in my car is an aftermarket unit, although I have no idea what brand (it has some purple bits on it if that helps).
Hoff is offline   Reply With Quote
Old 09-20-2011, 11:26 AM   #2
RadioBoy
No Disassemble!
RadioBoy's Avatar
If I recall 02-04 did NOT have lockout...but 05-06 Did.
'04 Spec V, Bone Stock ~ Except for all the stuff I've done to it.
RadioBoy is offline   Reply With Quote
Old 09-21-2011, 10:03 AM   #3
i68k
reverse lockout is a pull up level thats under the shift knob. you need to pull up on the lever to shift into reverse, if you dont pull up its not supposed to go into reverse.
Old 09-22-2011, 10:55 AM   #4
MisterNuts
OGT in 92 from the 1st EP
Garage
If your shifter has "purple bits" or looks aftermarket, I would highly recommend removing it asap. Any aftermarket short shifter that replaces the actual shifter will eventually snap your linkage, which will effectively leave you stranded (or at least stuck in one gear) until you can get it replaced.
2005 Supercharged SpecV @ 10psi
MisterNuts is offline   Reply With Quote
Old 09-22-2011, 11:26 AM   #5
RadioBoy
No Disassemble!
RadioBoy's Avatar
^^ Good advice~If I recall, the B and M on, in particualr, was a real cable eater.
Best bet would be to get a shift "Adapter" that clightly changes the geometry of the shift at the xmission housing. Mine's been worry free for 5+ years...
Old 09-26-2011, 09:56 PM   #6
Hoff
Part of the "partially disassembled state" of the car when I bought it was a missing shift knob and apparently a missing reverse lockout assembly. The orange plastic hook to the left of the shifter (under the shift boot) appears to be part of it, but the lever under the shift knob is gone. Oddly enough, a couple days after I originally posted this, my right side shift cable snapped. Fortunately, I was only 2 blocks from my house.
