Engine Code Help P0455, P0011, P0300 - B15sentra.net - Nissan Sentra Forum
Go Back   B15sentra.net - Nissan Sentra Forum > 2002 - 2006 SE-R & SPEC-V Section > Technical Discussions
Old 05-16-2010, 10:04 AM   #1
militaryball99
I was driving my car and after sitting for a couple of hours my check engine light came on. I took my car to Auto Zone and the following three codes appeared:
P0455
P0011
P0300
Are there any suggestions to help fix the problem?
militaryball99 is offline   Reply With Quote
Old 05-16-2010, 10:34 AM   #2
tjpitty
turtle power!!!
tjpitty's Avatar
have u tried to look up what the codes mean yet?
2002 aztec spec i/h/e/tbb/4ptJB/4pt trunk bar/mmi/ss/ground control/eibach rear sway/bsr/safc2 SOLD
2008 Vdub rabbit
tjpitty is offline   Reply With Quote
Old 05-16-2010, 08:53 PM   #3
militaryball99
Engine Trouble codes
P0455 EVAP control system gross leak detected
P0011 Intake Valve Timing Control Circuit Failure
P0300 Random Cylinder Misfire
Old 05-18-2010, 08:53 PM   #4
Le@r
For the P0455 I woould guess tighten the Fuel cap or make sure it seats properly on the filler neck. If this ckeck ok I would suggest to verify you're Vent control valve, she's located on the EVAP CANISTER. this valve gets always full of dirt and corrosion and fail open leaving a GROSS LEAK.
foe the oder two code mmmmm I would guess ure camshaft position sensor may be bad, this causing a desagree and induce a misfiring order. but inspect you're electric connections on these two part.
Le@r is offline   Reply With Quote
Old 05-19-2010, 07:11 AM   #5
militaryball99
Solution
Lear, Thanks for the suggestion. I changed the Camshaft sensor and it fixed the problem. Thanks again
