SMF Build 2010 - B15sentra.net - Nissan Sentra Forum
Go Back   B15sentra.net - Nissan Sentra Forum > News & Introductions > B15 MEMBER RIDES
Old 02-18-2010, 09:31 PM   #1
psushoe
EVOlving
psushoe's Avatar
Send a message via AIM to psushoe
SMF Build 2010
I haven't posted anything on my car in a while, so figured now was a good time for an update. I just got the new motor fired up the other day and the car sitting back on all four after being on jackstands for about 2.5 months. The old motor had detonation damage that would have cost a pretty penny to fix, so the new heart of the beast is a bluebird det. It's stock internals for now, but has jwt S4 cams. I stripped the motor when I got it and put in new seals, my newer oil pump, and newer water pump. Did a little powder coating as well to dress it up. I have to set the idle and base timing yet, but it starts and idles decently. Running a JWT ecu, STi yellows at 4bar, and z32 maf.
Here's the motor out of the car getting ready to go back in.
Back in the car.
Video of it running. Cams give it a little lope when the idle settles in. Should sound even better once I get the idle set better.
Here's also a couple shots of the suspension under the car and how the wheels sit. I modified the lower a-arms last year to raise the front roll center. As you can see in the picks, the a-arms are still sloped down from the car to the wheel. Most folks sitting this low have a-arms point towards the sky. Ignore the worn out tires
The wheels are 17x9 +35 with 235/40 tires. The front track is about 1.5" wider than stock due to the a-arm modifications. To get the same look on the stock suspension, you'd need about a +10 wheel (the fenders are rolled and pulled).
Upright and in the box... referring to autox of course
B15 MOTORSPORTS - Retired
SR20DET (SOLD) THE FORMER CAR
psushoe is offline   Reply With Quote
Old 02-18-2010, 09:56 PM   #2
charliepgt
hey i have some spare control arms how much for the RCA job? and I need those custom tie rod ends also... pm me some prices...
Project Attack Spec... C³garage
charliepgt is offline   Reply With Quote
Old 02-19-2010, 12:11 AM   #3
RobSE
Send a message via AIM to RobSE
For some reason the sickest B15s come only in Granite!
2001 Sentra SE w/PP 5 Spd
2006 GTO 18s 6spd
RobSE is offline   Reply With Quote
Old 02-19-2010, 08:05 AM   #4
piknockout
STU STi Build Complete
piknockout's Avatar
Send a message via AIM to piknockout
Beautiful and well done as always. I just can't wait until it's all set up with giant r-comps so I can take it for a spin (literally).
2006 Subaru Impreza WRX STi - Pics - Formerly 2003 Sunburst SE-R Spec V
3 STU - 2006 Philly STX Champ - 2007/2008 WDCR STX Champ - 2007/2008 A.I. STX Champ
Sponsored by Agile Automotive Performance
piknockout is offline   Reply With Quote
Old 02-19-2010, 08:22 AM   #5
psushoe
EVOlving
psushoe's Avatar
Thanks! I'm also thinking the 275/245 stagger will be cause for some oversteer induced spins Just need to get the motor fine tuned, then finish those fenders and get the wheel/tire package.
Old 02-19-2010, 08:23 AM   #6
psushoe
EVOlving
psushoe's Avatar
Funny how true that is. There's been a lot of well done granite SE's on this board.
Old 02-19-2010, 08:59 AM   #7
Philly02SpecV
Thats what she said
Send a message via AIM to Philly02SpecV
Looking good Aaron. Def gonna need a ride in it whenever we meet up next time.
Any idea on how much power this set up is making/will make?
1995 Mazda Protege DX sedan
Philly02SpecV is offline   Reply With Quote
Old 02-19-2010, 08:59 AM   #8
piknockout
piknockout's Avatar
Not enough.
Old 02-19-2010, 09:07 AM   #9
JP
Infamous
JP's Avatar
Garage
Send a message via AIM to JP
werd to that!
JP is offline   Reply With Quote
Old 02-19-2010, 09:39 AM   #10
mirrortints
VVL is good
Garage
Granite FTW
Nice job, keep it simple is the best way to do it.
2001 Sentra SE
mirrortints is offline   Reply With Quote
Old 02-19-2010, 10:46 AM   #11
psushoe
EVOlving
psushoe's Avatar
Simple on the outside...
Power should be between 1 and 1000whp. I'm thinking in the 320-350whp range, depending on how much 275/40/17 V710s can handle while autocrossing. The taller final gear (put a P11 in there last year) and 7700 rpm rev limit means 68mph in 2nd gear... also fun for autox
Old 02-19-2010, 04:16 PM   #12
TofuShop
PM A Mod For Custom Title
Send a message via AIM to TofuShop
wow, so 17x9 CAN fit in the front. what did you do to modify your a-arms?
TofuShop is offline   Reply With Quote
Old 02-19-2010, 05:35 PM   #13
psushoe
EVOlving
psushoe's Avatar
17x9 probably could fit on a stock a-arm car with a rolled front lip and the right offset. You just won't easily find that in 4x114.3. My car's front fenders are quite a bit wider than stock, because I rolled/pulled them to fit 265 rcomps a few years back. The a-arm mods included a custom machined piece, some metal fabrication skills, a welder, and heim joints. I'll dig out the pics and post them.
Old 02-20-2010, 06:21 AM   #14
aconfusedazn
wow. excuse me while i change my pants.
Ps: can you go full lock without rubbing on the inside of the fender wall?
(click here-->)Blackout SE-R--QR25DE-T
aconfusedazn is offline   Reply With Quote
Old 02-20-2010, 06:33 AM   #15
psushoe
EVOlving
psushoe's Avatar
Almost, but it will rub right at the end. Note that the SE rack goes farther lock to lock than the spec-v (and therefore has a tighter turning radius in stock form).
