Motor Mount Inserts - Nissan Sentra Forum - B15, B16 and B17 Sentra Forums
post #1 of 18 Old 06-27-2009, 05:34 AM Thread Starter
hxcjohn
Quoted: 0 Post(s)
Send a message via AIM to hxcjohn
(Thread Starter)
Motor Mount Inserts
I did a little searching around and didn't find quite the info i was looking for. I'm in the market for some MMIs and see that Energy Suspension and Prothane both make them. What I haven't heard is if one is better than the other. Read good things about both. It looks like the Prothane is a solid piece whereas the ES are 2 piece. The Prothane is about 30 dollars more, but looks to be pretty stout. Any advice?
2005 Silver Spec-V | AEM CAI
hxcjohn is offline
post #2 of 18 Old 06-27-2009, 08:26 AM
SHIFT_03SPECV
Quoted: 0 Post(s)
yes go with prothane. es are just inserts that try to fill in where the stock ones left out. prothane are actual replacements for the stock mounts made of urethane and are better at reducing engine movement. click on my screen name. i did a write up on the prothane install a while back
SHIFT_03SPECV is offline
post #3 of 18 Old 06-27-2009, 08:32 AM
SHIFT_03SPECV
Quoted: 0 Post(s)
post #4 of 18 Old 06-27-2009, 10:24 AM
Syhnthetik
Quoted: 0 Post(s)
Prothane's FTW!
02 Sentra SE-R Spec V
Supercharged
306.3whp and 264.1tq at 9.5psi
Syhnthetik is offline
post #5 of 18 Old 06-27-2009, 04:38 PM Thread Starter
hxcjohn
Quoted: 0 Post(s)
(Thread Starter)
Thanks for the replies fellas! I'll be ordering the Prothane today. Any link to the "Washer Mod"? Apparently I can't search for ****. LOL
hxcjohn is offline
post #6 of 18 Old 06-27-2009, 05:29 PM
BrianRitchie
Quoted: 0 Post(s)
Send a message via AIM to BrianRitchie
Cant find a link for you, but the washer mod is pretty self explanitory. when you take out the 4-17mm bolts to drop the crossmember and install the motor mounts you will see 4 rubber bushings. pop them out and replace them with the toughest washers you can find at the hardware store... done! I sprayed mine with undercoating after to keep them from rusting.
Hyundai master technician. Nissan enthusiast. 04 Sentra 1.8S 5 speed, 06 G35 6 speed
BrianRitchie is offline
post #7 of 18 Old 06-27-2009, 06:30 PM Thread Starter
hxcjohn
Quoted: 0 Post(s)
(Thread Starter)
Oh, ok makes sense now. Tried to order the Prothanes off http://neverenoughauto.com but I guess their PayPal is not working right.
[EDIT] Found the link: http://myspecv.com/f/t1255-4-wheelhop-aid.html
hxcjohn is offline
post #8 of 18 Old 02-02-2011, 09:41 PM
Bradycruze
Quoted: 0 Post(s)
A little help i here! I just opened the hood today to check the oil and noticed the bolt had fallen out. Not sure how long it had been out. The bolt was lying just underneath, so I picked it up and took the wife's Altima to the hardware store and picked up a new nut and two brass flat washers and reinstalled it. No torque wrench, just twisted it snug. The OEM 2003 Nissan Altima Motor Mount appeared sound.
Car goes in to dealer Monday for service (w/ 79k miles). Anything I should specifically ask them to check, given that the upper mount had not been secure for an unknown period of time?
Wow this is the first time i heard about those prothane's that's interesting.
Bradycruze is offline
post #9 of 18 Old 02-02-2011, 10:26 PM
johnnyb
Quoted: 0 Post(s)
Garage
Doesn't Energy Suspension also make full mounts (not just inserts)?
johnnyb is offline
post #10 of 18 Old 02-03-2011, 04:30 PM
MattspecV
Quoted: 0 Post(s)
Garage
I thought the prothane mounts caused alot more vibration. Which makes sense, them being one solid piece. Just figured I'd throw that in there incase it changes your/someones mind.
MattspecV is offline
post #11 of 18 Old 02-03-2011, 06:18 PM
Nerdbot
Quoted: 0 Post(s)
You get used to it
In all seriousness though, the cabin has a few rattles if everything isn't done up tight.
Prothane + washer mod = win.
Fully Built and Procharger equipped with custom CNC 2.35" pulley | JWT S1 Cams | HotShot | Stromung 3" DP catless | 3" Stromung Catback| Prothane MMI's | Rob's WHA|BC 7K Coilovers | Nismo Gramlight 57C | 2J Racing UpRev tuned | BAF grocery getter
Nerdbot is offline
post #12 of 18 Old 03-03-2011, 07:39 PM
kennedy3323
kennedy3323's Avatar
Quoted: 0 Post(s)
I belive at one point several years ago they did. If you want stiffer mounts then the polyurithane mounts from Energy Suspension you could just weld your own mounts in. However this will make the car vibrate like hell. No prolong damage as long as you ensure all bolts are torqued to the proper spec.
2005 Nissan SER Spec, Volcanic Orange, Needs more Cow Bell
<insert elite car mods here>
kennedy3323 is offline
post #13 of 18 Old 03-03-2011, 08:05 PM
03b15ser
Quoted: 0 Post(s)
Do motor mounts exist for the base auto SE-R? All I see are MM's for the Spec V
03b15ser is offline
post #14 of 18 Old 03-03-2011, 08:08 PM
P.P.H.
Quoted: 0 Post(s)
a solid mount is an overkill for a mildly modded street car. i've been running ES MMI's for 8 years now with no problems whatsoever. its a nice medium between performance and comfort.
P.P.H. is offline
post #15 of 18 Old 03-13-2011, 03:13 PM
i68k
Quoted: 0 Post(s)
yea i have the es mmi's for a long time, definately feel the vibrations, but nothing like having a solid mount. only giet minimal wheel hop with the mmi's which is a big improvement over stock rubber bushings.
03b15ser - i believe the ser and specv have the same mounts both are qr25, so im 99% sure the es mmis or other mounts will also fit your 03b15ser and install is identical
i68k is offline
User Tag List
