Cant tighten battery terminal cable to post - Nissan Sentra Forum - B15, B16 and B17 Sentra Forums
Thread Tools Rating: Thread Rating: 10 votes, 5.00 average.
post #1 of 36 Old 01-20-2009, 10:28 AM Thread Starter
Frodo
What U Brewing
Quoted: 0 Post(s)
(Thread Starter)
I keep having a problem with my negative battery terminal. No matter what I do I can to tighten the cable to get a tight fit. Can you but lead sleeves or something to go over the terminal post? I get power to my car and can run the radio, lights and everything but it wont start unless you get out and giggle the cable! I heard that you can replace the post but this is a OEM battery and I don't see anything that looks like it unscrews or comes off.
Beer.............
Frodo is offline
post #2 of 36 Old 01-20-2009, 10:37 AM
orangelloSE-R
geezinondowntheroad
orangelloSE-R's Avatar
Quoted: 2 Post(s)
Can't you just use some large pliers to "adjust" the post? The negative terminal & the foot of wire that attaches it to the body are cheap to replace if you break it.
2002 SE-R 5 speed
orangelloSE-R is offline
post #3 of 36 Old 01-20-2009, 10:52 AM Thread Starter
Frodo
What U Brewing
Quoted: 0 Post(s)
(Thread Starter)
To adjust do you mean squeeze or smash the post to deform it?
Beer.............
Frodo is offline
post #4 of 36 Old 01-20-2009, 10:54 AM
chiquae07
Informed Lurker
Quoted: 0 Post(s)
Send a message via AIM to chiquae07
i think that is what he is talking about.
you can always go get some new posts at napa or autozone and its like 4 bucks for the pair. if you ask them if you can have a couple tools to do this really quick, most will let you do it right there.
Suck up a kitten
Eat a butterfly
Replace with WRX
2001 Granite Sentra Se wit PP
Originally Posted by txspeccer View Post
Slow car races are exciting. For those 19 seconds until you hit 80 mph, nothing else matters.
chiquae07 is offline
post #5 of 36 Old 01-20-2009, 11:10 AM
VSpecSac
Rise from your grave
Quoted: 0 Post(s)
Send a message via AIM to VSpecSac
Why don't you try a new wire? it's really cheap and easier to replace. and you can get the right size that fits your post.
03'Aztec SpecV
Team Driven
Originally Posted by stephenspecv View Post
This site blows (B15Sentra.net)
I Vote BAN!!!!
VSpecSac is offline
post #6 of 36 Old 01-20-2009, 12:15 PM
BrianRitchie
Quoted: 0 Post(s)
Send a message via AIM to BrianRitchie
I had the SAME problem. My negative terminal was fully tightened, but not 100% making contact with the post. somtimes it would refuse to start after sitting over night, i would have to shake the terminal a few times and it would start right up.
Two words: Vice Grips.
put the terminal on the post, tighten fully. Squeeze the "ring" terminal together with the vice grips, tighten it down some more. pull on it to make sure its snug. done
Hyundai master technician. Nissan enthusiast. 04 Sentra 1.8S 5 speed, 06 G35 6 speed
BrianRitchie is offline
post #7 of 36 Old 01-20-2009, 04:15 PM
Leusent
Quoted: 0 Post(s)
The correct solution to this problem is to replace your terminal clamps, as they're obviously worn out.
Craig
Summer: 2007 Honda DOHC I-4 6Spd CBR600RR Black
Winter: 1995 Dodge SOHC I-4 5Spd Neon Highline Green
Other: 2001 Nissan DOHC I-4 5Spd Sentra XE Blue
Leusent is offline
post #8 of 36 Old 01-20-2009, 04:44 PM
RobSE
Quoted: 1 Post(s)
Send a message via AIM to RobSE
Put a screw between at the spot where the clamp meets to the cable, worked for me for the last 2 years.
2001 Sentra SE w/PP 5 Spd
2006 GTO 18s 6spd
RobSE is offline
post #9 of 36 Old 01-20-2009, 05:36 PM
easy life
Drift king
Quoted: 1 Post(s)
this crap happens to my positive clamp. robse i'm gonna have to give ur method a try.
06 Silverstone S2000
03 Blackout Spec- totaled 2/10
Nismo header, K&N flat panel filter,Nismo leather shift knob, 5000k HID headlights, 3000k HID fogs, Brembo blanks, Hawks HPS pads, Fuzion HRi's
easy life is offline
post #10 of 36 Old 01-20-2009, 07:00 PM
orangelloSE-R
geezinondowntheroad
Quoted: 2 Post(s)
Yep, like duder said, make with the vice grips. Honestly, replacing mine didn't take a half hour (+ i cleaned off the metal piece it screws into for a better ground).
2002 SE-R 5 speed
post #11 of 36 Old 01-20-2009, 07:10 PM
AVP_85
Quoted: 0 Post(s)
Honestly, I just tighten them down as far as they go then I give them a twist and I have no problem with them coming loose. I never have to loosen my terminal's when removing my battery because I just twist them the opposite way and they come loose. I do have to agree with Leusent about the proper solution.
AVP_85 is offline
post #12 of 36 Old 01-20-2009, 11:00 PM
Hooch_SE-R
Quoted: 0 Post(s)
Craig
+1. Easy, cheap, and better quality for 100% fixed status. The only pain is getting the old one off the wire.
2002 Black SE-R 5 speed.
Nismo I, WRP IM Spacer, OBX H, XS Power C/B
S/Shifter, G/W
Motegi LC5 17x8 with 235/40/17 Falken Azenis RT-615, Tien SS, Eibach Sway bars, Nismo Lower Tie Bar, Specless Trunk Bar
Waiting to go on: WRP U/D Crank Pulley, WRP Throttle Spacer, WRP U/D Steering Pulley
Hooch_SE-R is offline
post #13 of 36 Old 01-20-2009, 11:13 PM
chiquae07
Informed Lurker
Quoted: 0 Post(s)
10 seconds. what pain? its harder to change oil than to change the clamps. the tricky part is getting the wire into the new post without poking the crap out of yourself.
Suck up a kitten
Eat a butterfly
Replace with WRX
post #14 of 36 Old 01-20-2009, 11:42 PM
GREEN01GXE
Quoted: 0 Post(s)
Send a message via AIM to GREEN01GXE
werd, this is a 5 min job with a large pair of snips or cable cutter, a blade, and a screw driver.
clip, strip, and clamp
thats where its at baby
yeah
Originally Posted by pilotenfs
.. the question is.. will the engine tough that bigger combustion?
GREEN01GXE is offline
post #15 of 36 Old 01-21-2009, 08:45 AM
SPECtacular B15
2003 SE-R Spec V
Quoted: 0 Post(s)
SPECtacular B15 is offline
User Tag List
