Dash lights not working, voltage on dimmer switch? - Nissan Sentra Forum - B15, B16 and B17 Sentra Forums
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average.
post #1 of 9 Old 01-04-2009, 03:29 PM Thread Starter
bronigs
Quoted: 0 Post(s)
(Thread Starter)
Hey
So I was installing a new audio headunit in my 2003 Sentra, I couldn't find a wiring harness so I cut mine, and when I cut it the illumination wire touched a ground the lights in the car went on for a second and turned off. I thought nothing of it and finished my install of the headunit. Then a few hours later I went to drive the car and the illumintaion didnt work. I think the dimmer switch is burn't (I checked all the fuses and all are ok). But now on the dimmer switch there are three wires, the yellow/red has 12v when the lights are on, the green/red has 12v when the light are on and the black is ground. It doesn't make sense to me that both wires have voltage, is this right can anyone verify. Also the dimmer switch has resistance in it but it doesn't change when the knob is moved.
bronigs is offline
post #2 of 9 Old 01-05-2009, 09:39 PM Thread Starter
bronigs
Quoted: 0 Post(s)
(Thread Starter)
figured it out. It was the dimmer switch.
I found an easy fix was to short the red/yellow to the black, now lights work on the dash.
bronigs is offline
post #3 of 9 Old 01-05-2009, 10:32 PM
JP
Infamous
JP's Avatar
Quoted: 25 Post(s)
Garage
Send a message via AIM to JP
I think I have a dimmer switch laying around. Brand new in box. If your interested I can sell it cheaper then you would buy it from a dealer.
JP is offline
post #4 of 9 Old 01-05-2009, 11:08 PM
JP
Infamous
JP's Avatar
Quoted: 25 Post(s)
Garage
I am pretty sure I had it, but after a quick look in the garage I don't see it. It's cold out and I'm not going to search to much for yet. I will look again when it's a little warmer.
JP is offline
post #5 of 9 Old 01-05-2009, 11:54 PM
Principle
Quoted: 0 Post(s)
Send a message via AIM to Principle
Fuse?
Founder of QG18DE.NET
http://www.qg18de.net/
Principle is offline
post #6 of 9 Old 01-06-2009, 12:26 AM
JP
Infamous
JP's Avatar
Quoted: 25 Post(s)
Garage
dimmer switch!
JP is offline
post #7 of 9 Old 01-06-2009, 09:39 AM
melly mel
Quoted: 0 Post(s)
Send a message via AIM to melly mel
Installing aftermarket stereo.
Step 1. Disconnect negative battery terminal.
Step 2. Make sure you do step one.
etc.
2003 Sentra Spec V - GONE
:Nismo CAI:SSA Header:T-Pros Midpipe:Custom 2.5" CBE:JWT Cams:Axxion STS w/ Centering Adaptor:UR Pulley:SAFCII tuned w/ ZT2 Wideband:ES MMI's:Tein S-Techs:4PT LTB:Seibon CF Hood:Bronze Rota Subzeros:iRotor D/S Rotors:TechnaFit Brake and Clutch Lines:NX 75 Shot:
melly mel is offline
post #8 of 9 Old 01-06-2009, 03:09 PM Thread Starter
bronigs
Quoted: 0 Post(s)
(Thread Starter)
melly mel I agree with you just tried to do it too fast, I've installed probably around 20 systems and never had a problem. I always disconnect the positive terminal (negative works too). Installing stuff fast isn't always the best.
I know its definitely the dimmer switch as a lot of accessories are attached to the fuse that lights up the dash lights, such as the trunk, windows, etc... Also I check all my fuses and there all good. I don't know an easy way to check relay's so I didn't check any.
JP check your PM's.
bronigs is offline
post #9 of 9 Old 09-06-2011, 10:32 AM
mre1208
Quoted: 0 Post(s)
woohoo! digging up a very old thread....I had the wonderful problem of no dash lights, and upon reading this, I pulled out the unit and tried the method of putting the wires to the black, and it worked...so i went to actually place it where i keep the wire permanently and the whole unit stops working before i even get there...i've rewired all the power perfectly, undid the dash lights to see if that would fix it, the fuse(s) are fine...i have NO clue?!?!?!?! wtf?
mre1208 is offline
User Tag List
