Fuse diagram - Nissan Sentra Forum - B15, B16 and B17 Sentra Forums
Thread Tools Rating: Thread Rating: 13 votes, 5.00 average.
post #1 of 21 Old 12-06-2008, 04:24 PM Thread Starter
qrush
Quoted: 0 Post(s)
(Thread Starter)
Fuse diagram
Ive tried searching for it and no luck anywhere. I am looking for the diagram for the fuse box under the hood. I have searched here and google and no luck. I keep blowing a 25a fuse and it makes the car stall when i try to accelarate. To top it off there is no code that is being thrown due to it either. Anyone else have this problem?
Originally Posted by shanno575
duct tape. fixes anything
04 ser spec v xs power header cai
qrush is offline
post #2 of 21 Old 12-06-2008, 06:42 PM
civiceater
Quoted: 5 Post(s)
You got an FSM? It should be in there. Also the cap of the fuse box should have it labeled.
03 Silver Spec-I/H/E/SS/TB mod/MMI/B&G springs/BSR/FidanzaFW/CMFX100/Nismo: LTB/RSB/FSB/Rims/Hankook Ventus V12 evo 225/45/17 14.923@95.732
91 Maroon 240 Coupe- Stock - smashed sold
http://www.b15sentra.net/forums/showthread.php?t=185353
civiceater is offline
post #3 of 21 Old 12-06-2008, 06:48 PM Thread Starter
qrush
Quoted: 0 Post(s)
(Thread Starter)
i read the fsm from front to back and its not in there, and there is not a sticker under the lid for the box either. Nissan decided to be bastards on some of there vehicles cuz my buddys 08 titan doesnt have it either.
qrush is offline
post #4 of 21 Old 12-06-2008, 08:24 PM
chiquae07
Informed Lurker
Quoted: 0 Post(s)
Send a message via AIM to chiquae07
i would take a picture of mine from the SE but idk if it would be any help
Suck up a kitten
Eat a butterfly
Replace with WRX
2001 Granite Sentra Se wit PP
Originally Posted by txspeccer View Post
Slow car races are exciting. For those 19 seconds until you hit 80 mph, nothing else matters.
chiquae07 is offline
post #5 of 21 Old 12-07-2008, 01:42 AM
civiceater
Quoted: 5 Post(s)
Take a pic of where the fuse is at. Also I looked into my FSM fuse block and I can't seem to find a 25a fuse. You sure you're supposed to have a 25a in there? I'll check my car tomorrow to make sure.
post #6 of 21 Old 12-07-2008, 02:02 AM Thread Starter
qrush
Quoted: 0 Post(s)
(Thread Starter)
The 25a fuse was there when i opened the fuse box, and when i tested them it was the only one burnt out. I think that it may be for the fuel pump but i cannot be sure without the the diagram.
qrush is offline
post #7 of 21 Old 12-08-2008, 01:13 AM
civiceater
Quoted: 5 Post(s)
Dude can you post a pic say from the FSM which fuse you're blowing so I can match it. I looked at my fuses right next to the battery and I can't find a 25a fuse there. The biggest micro fuse there is a 20a, then it goes to the FL type and the 120a battery/alternator one.
post #8 of 21 Old 12-08-2008, 09:15 PM Thread Starter
qrush
Quoted: 0 Post(s)
(Thread Starter)
Ill get a pic tomorrow a lil dark right now. I never found it in the fsm nor on the inside of the fuse box, thats what has me questioning what goes there and what its for.
qrush is offline
post #9 of 21 Old 12-09-2008, 12:13 AM
EXM_04SE-RSpecV
EXM_04SE-RSpecV's Avatar
Quoted: 0 Post(s)
Send a message via AIM to EXM_04SE-RSpecV
heres a pic hope it helps you out!
EXM_04SE-RSpecV is offline
post #10 of 21 Old 12-09-2008, 09:41 PM Thread Starter
qrush
Quoted: 0 Post(s)
(Thread Starter)
well this is a pic of the fuse box
the white one on the bottom that you cannot see cuz my phone sucks is the 25a fuse. Thanks exm.Is that the inside fuse panel or the one next to the battery?
qrush is offline
post #11 of 21 Old 12-09-2008, 10:11 PM
chiquae07
Informed Lurker
Quoted: 0 Post(s)
exm's is the one that should be on the back of the coin tray thing on the right side of the steering column.
Suck up a kitten
Eat a butterfly
Replace with WRX
post #12 of 21 Old 12-09-2008, 10:14 PM
JPKSPECV
Quoted: 0 Post(s)
My FSM shows that to be the fuse for the ECM Relay, ECM, and immobilizer control unit. I have no idea how to fix the problem you are having, though.
JPKSPECV is offline
post #13 of 21 Old 12-11-2008, 02:26 AM
civiceater
Quoted: 5 Post(s)
Dude how did you end up with a 25amp fuse there? The FSM for 04 says that should only be a 10amp? If you check the FSM PG-55. The fuse diagram/amp is there. And if I'm looking at the picture right, that should be fuse#36. Then scroll up to PG-3 and it shows fuse#36 is what JPK mentioned and showed 10amps.
The only explaination I can think of is that somebody messed your car up and put a 25a there and everytime you're accelerating you're shorting something out. And since the 25a has been there for a while I'm assuming damage to those circuits it's protecting has been done. If you're lucky and nothing is burned, try swapping it out with a 10a and drive it like you would normally or try to blow that fuse. If it blows you got a short somewhere, if not and you're ok then you got lucky.
post #14 of 21 Old 12-11-2008, 08:21 AM Thread Starter
qrush
Quoted: 0 Post(s)
(Thread Starter)
Thanks civiceater ill give that a try.
qrush is offline
post #15 of 21 Old 12-11-2008, 09:52 AM
Salem_MA_SpecV
Quoted: 0 Post(s)
Uhh, If he is blowing a 25A fuse, he will surely blow a 10A.
Anybody got a picture of the fuse diagram on the cover of the fuse box under the hood?
_ __________=__
\\@([____]_____()
_/\|-[____]
\____/
Salem_MA_SpecV is offline
User Tag List
