Sound from Steering When I Turn The Wheel? - Nissan Sentra Forum - B15, B16 and B17 Sentra Forums
post #1 of 9 Old 11-27-2008, 03:24 PM Thread Starter
Toniee
Quoted: 0 Post(s)
(Thread Starter)
My sentra 2001 has 105K miles, getting old I know, I just changed the tires, shocks and struts.
I have been hearing noises when I turn the wheel and it's annoying, it sounds like a twisting metal (like on a ship). Sounds pretty bad, what do you think it can be?
Toniee is offline
post #2 of 9 Old 11-27-2008, 04:06 PM
sunnyboy
Quoted: 0 Post(s)
twisting metal? does it sound like a scream? if so check ur power steering belt
sunnyboy is offline
post #3 of 9 Old 11-27-2008, 06:42 PM
dmac0923
dmac0923
Quoted: 0 Post(s)
probably more like a creaking noise he meant. i would make sure that when the place installed the struts they put the rubber insulators back on the top of the struts
2002 Spec V
3 Ford Explorer's 1995-2002
2002 Ford Ranger
1970, 1969, 1968 Mustangs
dmac0923 is offline
post #4 of 9 Old 11-27-2008, 07:14 PM Thread Starter
Toniee
Quoted: 0 Post(s)
(Thread Starter)
Yea the rubber insulators went back on it, it made that creeking noise even before I got the struts changed. It is also more difficult to turn the steering wheel than most other cars.
Toniee is offline
post #5 of 9 Old 11-27-2008, 08:27 PM
dmac0923
dmac0923
Quoted: 0 Post(s)
check if the u joint on the steering shaft is worn and binding up
2002 Spec V
2002 Ford Ranger
dmac0923 is offline
post #6 of 9 Old 11-28-2008, 12:28 PM
audio1der
Bow to your SE GOD
Quoted: 1 Post(s)
I had a rock caught in my steering rack that sounded awful, but it was sure a cheap fix
Worth a look.
'01 SE wP/P 5spd.
Tein SS w/B15MS rear mounts, Nismo RSB, timing @ 19*, Magnaflow 2.25", ES shifter/RTA bushings, over-filled mm's, Techna-Fit SS lines w/Motul 5.1, HPS pads, Falken 912's on powdercoated 16's, dual batts, Boston Acoustics, Audioque, Silver Flute, Alpine and Phoenix Gold ICE
audio1der is offline
post #7 of 9 Old 11-28-2008, 12:31 PM
phantasm
Quoted: 0 Post(s)
did you check your power steering fluid level? Could be as simple as that.
phantasm is offline
post #8 of 9 Old 02-17-2009, 01:13 PM
Boostin4g63
Quoted: 0 Post(s)
Sorry to bring back a old forum......But my car (02 Sentra GXE, Automatic, Mileage approx - 128K) is giving me kind of same problem that Toniee was having. My Problem is that when i start my car in the morning my power steering seems not to work and i also hear a squeaking sound. Anytime i try to turn my steering wheel from a car being on complete stop it is just so hard to turn as if i have no powersteering. I checked my PS fluid and its on Cold Max (what the difference beetween hot max and cold max)....also my PS fluid is soo black/dark colored. What do you guys think the problem might be.
Any help is appreciated.
Thanks
Rob
Boostin4g63 is offline
post #9 of 9 Old 02-17-2009, 06:41 PM
phantasm
Quoted: 0 Post(s)
delete. i reposted the same thing I posted 2 months ago.
phantasm is offline
User Tag List
