Thread Tools | Rate Thread |
#1 |
FS: 2002 Nissan Sentra SE-R Spec V Black, a lot of mods
PRICE REDUCED
Check post #13 with oil analysis results Updated w/ pics For Sale In So Cal 2002 Nissan Sentra SE-R Spec V Black ~133,500 miles $4000 OBO I am willing to swap my aftermarket parts for your OEM parts + cash, but you have to do all the work. My rims/tires for your rims/tires + $1000, for example PM me if interested, I live in Downey, CA The car dyno'd at 195 WHP when I had an S-AFC II installed. It only gained me 5 HP, I removed it so I now should have 190 WHP I used Redline 10W30 for about 100,000 miles, then switched to Castrol Syntec 0W30 (aka German Castrol). I use Redline MT90 for the transmission I use Redline Water Wetter with a 70% water and 30% coolant mix in the radiator. I use Motul RBF600 for the brake and clutch fluid I have done an oil analysis from Blackstone Labs on almost every oil change and will provide you with the paperwork. I also have the data from almost every gas fillup (miles, price, gallons, etc) Some issues: Dings and scratches typical of a 6 year old car Front bumper and lip has lots of marks from bugs hitting it (lots of trips between San Jose and Los Angeles) Front and Rear bumpers have the trademark "Sentra Sag" in the corners Airbag light is in because I swapped to a Sparco steering wheel Check Engine light is on showing a Misfire code becuase of the JWT flywheel, and camshafts. There is no misfire. I had the headgasket leak at 65,000, but oil analysis caught it before any damage was done, I replaced it, and further oil analysis shows the engine in perfect shape Sparco Pro 2000 seat has a large tear in it around the hip area. You can see some pics on my Cardomain page from back in the day before all the scratches and dings and saggy bumpers here: http://www.cardomain.com/ride/295844/2 Mods: Engine: AEM Intake Hotshot Header Mossy Performance Exhaust UR Underdrive Pulley JWT Camshafts JWT Balance Shaft Removal NGK Copper Spark Plugs Odyssey Lightweight Battery 300ZX Radiator Cap Place Racing Motor Mounts Kartboy Exhaust Hangers Gourmet Garage Grounding Wires Hondata Phenolic Intake Manifold Spacer Throttle Body Coolant Bypass Mod Ported and Polished Throttle Body by Dan Paramore Racing Ported and Polished Intake Manifold by Dan Paramore Racing Ported and Polished Head by Dan Paramore Racing (Stage 1) Ceramic Coated Valves and Stems Microlon Treatment of Camshaft Bearings Relocated O2 Sensor Behind Main Cat Drivetrain and Wheels: JWT Clutch JWT Flywheel B&M Short Shifter Volk TE-37 15x7 +40 wheels Falken Ziex 912 225/50/15 with less than 6000 miles (need to double check the size) Crown Stainless Steel Brake Lines Crown Stainless Steel Clutch Line Carbotech Bobcat Brake Pads Powerslot Rotors Suspension Nismo Dampers Nismo Springs Nismo Front Strut Tower Bar Nismo Front Antisway Bar Nismo Front Lower Tie Bar Nismo Bushing Kit Motivational Engineering Upper Rear Suspension Mounts Front 0.2 degree toe, -2.5 degree camber by West End Alignment Rear Beam bent to 0 degree toe by West End Alignment Exterior: World Challenge sideskirts Carbon Fiber Hood with Hoodpins Clear Turn Signal Bulbs Nissan Altima OEM Gas Cap Holder b15sentra.net sticker ![]() Interior: Sparco Pro2000 driver seat (black/grey) Razo Pedal Covers Infinity Kappa Perfect 6.1 (front components) Infinity Kappa 65.2i (rear 2-ways) US Acoustics USX-2100 Amplifier Monster cables Stubby Antenna Nismo Key Broadway Convex Rearview Mirror ![]() ![]() ![]() ![]() ![]() ![]()
2002 Nissan Sentra SE-R Spec V Blackout The Sig monster ate my sig Last edited by pio!pio!; 12-06-2008 at 02:40 PM. |
| Sponsored Links | |||
Advertisement | |||
#2 |
Partout?
#3 |
nah i dont have the original parts anymore
2002 Nissan Sentra SE-R Spec V Blackout The Sig monster ate my sig |
#4 | |
E-Thuggin
swap for OE parts?
02 Aztec Red Spec- 100k+ ![]() 4-1 Header,CAI, Greddy Evo2,Nismo RSB,Ksport GT Pro's,E55 Retrofit 6000k,3000k Foglights,Mach 1,Red Top,Impulse Mechanisms Crank Pulley,5%,Rota Grids, Falken Ziex's, VIS Evo Style CF Hood,CF style Tails,Pioneer Premier HU,Alpine Type S Coax 6.5's. Quote:
#5 |
what things are you interested in?
#6 |
If you are going to part out how much you are looking for nismo rsb?
#7 |
Vibrant Blue Army
Bump for a legit seller.
FS: 03 Vibrant Blue Auto SE-R w/SP |
#8 |
I will send you my non ported IM and TB for your ported IM and TB? LMK PlZ
02 Aztec Red SpecV - Nismo CAI / Nismo Suspension / XS Power 4-1 Header and Exhaust / UR Crank Pulley / JWT Cams / JWT Flywheel / WRP TBS / WRP IMS / WRP Cam Sprocket at -4 / Faktion SS / ES MMI's / EBC Brakes / EaglEye 6k Hids / ViS Carbon Fiber OEM Hood |
#9 | |
E-Thuggin
Pm Has Been Sent
#10 |
buuump
#11 |
very few track days...
![]() Sad to see you get rid of one of my favorite B15s. Someone should snap this up! |
#12 |
that's my fav shot..was my wallpaper at work for awhile
#13 |
Code:
Mi/Hr on Oil 3500 5162 5138 1949 6225 5405 6016 3980 3900 6275 6448 7185 8090 8370 Mi/Hr on Unit 30500 35662 40800 42749 48974 54379 60395 64375 70914 90275 96723 103908 111998 120368 Sample Date 8/13/2003 10/21/2003 1/18/2004 2/23/2004 6/15/2004 9/27/2004 12/24/2004 3/1/2005 7/2/2005 3/3/2006 1/1/2007 4/28/2007 9/15/2007 2/19/2008 Aluminum 2 2 3 6 4 6 6 3 3 1 3 1 2 8 Chromium 1 1 1 1 1 1 1 1 0 1 1 1 0 1 Iron 6 10 6 12 13 6 9 6 10 7 9 11 15 20 Copper 4 6 4 3 6 5 3 2 4 3 3 5 7 6 Lead 3 2 0 2 8 4 4 0 2 0 0 0 0 0 Tin 0 0 0 1 0 0 0 2 2 0 0 2 5 4 Molybdenum 623 594 430 588 627 368 528 222 96 595 541 608 778 703 Nickel 0 1 0 0 0 0 1 0 0 1 1 1 4 7 Manganese 0 0 0 0 0 0 0 0 0 0 0 0 1 0 Silver 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Titanium 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Potassium 20 17 13 5 4 1 13 114 4 1 1 0 4 4 Boron 20 5 59 14 9 5 15 51 42 9 14 12 24 21 Silicon 13 13 12 21 20 16 15 9 9 25 16 16 17 18 Sodium 16 15 13 25 30 17 25 87 8 18 20 20 26 29 Calcium 3072 3113 2893 3045 3103 2872 3124 1953 2565 1945 2859 2723 3268 2929 Magnesium 7 8 9 6 7 7 0 7 11 18 19 14 14 11 Phophorus 1275 1160 990 1197 1172 1103 1275 736 724 1190 1181 1140 1073 1040 Zinc 1405 1261 1193 1312 1326 1248 1507 774 893 1351 1308 1340 1309 1227 Barium 1 1 1 1 1 1 1 0 0 0 0 0 0 1 Visc@210F 68.6 69.4 65.5 66.3 68.2 68.7 67 64 59.6 63.8 66.5 66 63.7 67 Flashpoint 445 400 430 460 440 445 430 440 425 415 425 425 395 435 Fuel % 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 Antifreeze % 0 0 0 0 0 0 0 POS 0 0 0 0 0 0 Water % 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Insolubules % 0.2 0.2 0.3 0.3 0.4 0.3 0.4 0.3 0.1 0.3 0.4 0.3 0.3 0.3 TBN 5.2 3.7 4.6 6.3 3.5 3.9 2.8 1 4.3 3.9 2.6 4.6 2
#14 |
still for sale
#15 |
bump price drop
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Rate This Thread | |
