B15sentra.net - Nissan Sentra Forum
Go Back   B15sentra.net - Nissan Sentra Forum > 2000-2006 B15 Nissan Sentra > Modifications - Performance
Register Home Forum Active Topics Parts Catalog FAQ Search Today's Posts Mark Forums Read
Old 04-24-2008, 08:18 PM   #1
sentra001
Send a message via MSN to sentra001
Dyno Pulstar Plugs!
Today I finally got the chance to test these Pulstar plugs.....on the dyno.
We did three pulls with NGK G-power platinum plugs. Then installed the Pulstar plugs and did another three pulls. Needless to say there were no gains at all from the Pulstar plugs.
The pros at DL Motorsports use a DYNOJET dyno which is very consistant. All six pulls read the same HP and Torque, using the NGK's and the Pulstars.
Graph will be shown tomorrow. I'm having some technical difficulties
2001 Sentra SE SR20DE w/ AEM C/A/I with Dry Flow AEM Filter, JVVT Header with 2.5 " downpipe into 2.5 Custom Catback, Cross Drilled on all four corners, Koni Yellows with H&R Springs, Fidanza 8lbs flywheel and stage 2 clutch. Complimented with a 75 shot of Nitrous.
sentra001 is offline   Reply With Quote
Old 04-24-2008, 08:25 PM   #2
Y2K SE
105,000 miles
Y2K SE's Avatar
No gains, eh? Imagine that.
2000 Heatwave Nissan Sentra SE w/ Performance Package
NISMo Suspension | NISMo 17x7.5 bronze wheels
Alpine CDA-9835 HU | Kenwood KAC-9152d Amp | 12" Alpine Type-R
Llumar 28%/38% Window Tint
Y2K SE is offline   Reply With Quote
Old 04-24-2008, 08:27 PM   #3
paperdukie
hmmmmmm....what a suprise
2004 1.8s
CAI, K&N Filter, AEM Bypass valve, Megan Racing Strut Bar, WRP Crank pulley, Bronze 02 Spec V Wheels, Falken Ziex 512s 215/45/17, Tein S-Techs, Apexcone 6000k HID
Future:HKS Sport Catback, Tein Basics, Header, Nismo RSB, Mach1 Lip
paperdukie is offline   Reply With Quote
Old 04-24-2008, 08:57 PM   #4
drewsky
What benefits does this pulstar plug advertise, come on, sparkplugs? They either work or they don't...
Hey Yooooo!
drewsky is offline   Reply With Quote
Old 04-24-2008, 09:00 PM   #5
txspeccer
You've Been Tomahawked
Originally Posted by drewsky
What benefits does this pulstar plug advertise?
http://www.b15sentra.net/forums/showthread.php?t=161456
Originally Posted by Sebba View Post
Did someone have a skeez fest on those?
txspeccer is offline   Reply With Quote
Old 04-24-2008, 09:05 PM   #6
GregFarz78
Audio Junkie
Send a message via AIM to GregFarz78
no gains from spark plugs...wow I'm shocked
2002 SE-R Spec V
1989 240SX Coupe
Greg's Pics
GrafxWerks makes your Nissan stand out!
GregFarz78 is offline   Reply With Quote
Old 04-24-2008, 09:19 PM   #7
fatloserboi
good job.. thanks for doin this dyno for us! I figured as much...
'02 Spec V - Nismo CAI, Nismo Cat-Back, Nismo Suspension Set + FSB + RSB + LTB + STB, Nismo Camshafts, Nismo Header w/o cat, Nismo Rims w/ Azenis RT-615's 225/45/17.
Parked next to a Stupid Neon
fatloserboi is offline   Reply With Quote
Old 04-24-2008, 09:47 PM   #8
Valves
Send a message via AIM to Valves
I thought maybe Modified magazine had been paid off to run an article saying they got 11whp out of a Z with these. I'm going to cancel my subscription now. What a bunch of bs.
03 Spec- (sold)
04 Volvo S60 R 6 speed.
Valves is offline   Reply With Quote
Old 04-24-2008, 10:01 PM   #9
sentra001
I am having a little difficulty posting the dyno chart. I'll get some technical support tomorrow and then hopefully post the chart.
For now, I'll give you guys the numbers.
NGK G-Power 133.61 max hp 128.75 max torque
Pulstar Plugs 133.50 max hp 129.93 max torque
I must make it known that the quality of these Pulstar plugs are very poor. I had 1 of the Pulstar plugs seperate on me. It seperated where the porcelien goes inside the metal base. There was no reason that should have happened. Maybe during shipping it inherited a hairline crack. But even so, the package should've been better. The package was very slim and didn't have any protection from the top of the package. I had to use a NGK platinum plug for cylinder 4 to complete the test.
However, the only difference is that the Pulstar plugs showed a smoother torque curve from 2000 rpm to 5000 rpm, but was in no way higher in torque compared to the NGK's.
Old 04-24-2008, 10:02 PM   #10
speedjunkie
Send a message via AIM to speedjunkie Send a message via Yahoo to speedjunkie
if the plugs are old or fouled then changing the plugs will result in power being REgained, but gains from spark plugs lol...
On a quest to prove everyone wrong on what they think they know about the QG18DE
Brand Spanking New Forum For Sentra GXE, XE, and 1.8S Owners just search google for qg18de and come join our forum
speedjunkie is offline   Reply With Quote
Old 04-24-2008, 10:08 PM   #11
sentra001
This is exactly what the plug looked like after i pulled out the spark plug socket from the spark plug port of the engine. This portion was stuck in the socket because the spark plug socket has a rubber o-ring that holds the plug in the socket for removal purposes. Apparently....I'm not the first to have this happen too.
Old 04-24-2008, 10:26 PM   #12
cysco00
Send a message via AIM to cysco00
Hey guys, im sorry I haven't posted in a while but I want to link a post form my local forums for you all to read. I want to pretty much retract my previous statment of endorsement for these plugs. Read this:
http://racingsouthwest.com/forums/in...howtopic=57900
I do have to say though, that I did feel alot better throttle response when they were in....maybe just me...IDK. But I have also had no response from Enerpulse about doing this kind of test on my car again on an INDEPENDENT dyno!!
NGK IRIDIUM FTMFW!!!!
Cisco C.
cysco00 is offline   Reply With Quote
Old 04-24-2008, 10:40 PM   #13
txspeccer
Cisco C.
ROOFLES. Maybe next time you won't be such a sackrider...
Old 04-24-2008, 11:03 PM   #14
Y2K SE
105,000 miles
Y2K SE's Avatar
Replacing old spark plugs will do that.
Old 04-25-2008, 04:57 AM   #15
fatloserboi
placebo effect.. maybe next time you wont argue w/ us about how these plug made all sorts of power on ur vehicle...
alright thats my one and only shot I'll be taken.. I'm glad this test disproved these plugs.. I wouldnt want another wrp ims situation to occur again..
good stuff to all the ppl involved...
vB code is On
Powered by vBulletin® Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
