Thread Tools | Rate Thread |
#1 | |
Carrrrrne asada
How-to R&R QR CPS
My CPS started crapping out on me when I was on my way back from Xmas vacation. Luckily I made it back home before it totally crapped out. It cost $37.23 (in stock) from the dealer. Anywhere else I would've had to special order it. Since I had to replace mine anyways I thought I should take some pictures for the DIYers. I know Nissan has a recall on this so this may come in handy for some people pretty soon. I personally don't like taking my car to a dealer if possible. This is the best possible way for me to change the CPS.
The process as a whole doesn't take long at all the way I did it. Maybe just over 30 mins just because it's 35* outside with 15mph wind gusts. Tools Needed: 1/4 ratchet 10mm deep socket 12mm socket flathead screwdriver Stool/ block (for shorter people, yeah I used one, so what) 1) Disconnect Battery (not sure if it's necessary, doesn't hurt) 2) I took off my SRI just for easier access. Also, to get ready to stick my head/arm down there. ![]() 3) Take off the 12mm bolt that WAS holding the bracket pictured. With the bracket not secured to the block it was much easier to access the CPS. ![]() 4) Shove your arm down and take off the 10mm bolt holding the CPS in place. ![]() 5) remove old CPS ![]() 6) install new CPS and reinstall bolt ![]() ![]() 7) Reinstall bolt for bracket 8) Reinstall intake (if removed) 9) Reconnect Battery (if disconnected) 10) Start it up and have fun driving again!!! If anyone has any inputs, comments, or ways to improve on it then please share. ~Bryan
| Sponsored Links | |||
Advertisement | |||
#2 |
nice write up
QR25DE-T/B16HYBRID BUILDUP THREAD http://www.b15sentra.net/forums/showthread.php?t=178875 |
#3 | |
geezinondowntheroad
Nice! Thanks, i'll need this eventually.
#4 |
Great writeup thanks.
Megan header / ES MMi / Greddy EVO muffler / Custom 2.5" SS Catback / M-Sport & KVR Slotted Rotors / EBC Redstuff pads / K&N CAI / TBS / Crank Pulley / TWM SS / Trunk Brace / Stillen Lip / 6000k HID / BFG & Dunlop 225/45's / NGK Ir / Redline Mix http://www.cardomain.com/ride/742639 |
#5 |
Texas Aggie
wait so, the replacement has a different sensor head on it than the old one?
This is what that last recall was about right? |
#6 | ||
Carrrrrne asada
When my CPS did finally go out, every autoparts store magically had to special order a new CPS. I'm only guessing that it was due to Nissan recalling all the older ones.
#7 |
yea i am having this problem right now. same things rpms dropping off sometimes causing stalling. about to head over to the dealer and get a new sensor. the auto parts store by me doesn't have the medal one i want that one.
Sunburst 03 Spec-V | Extreme Dimensions B-2 body kit | NISMO cat-less headers | MagnaFlow Catback Exhaust | NISMO CAI | Xenon HID kit 12k |
#8 |
sticky?
'02 Spec V - Nismo CAI, Nismo Cat-Back, Nismo Suspension Set + FSB + RSB + LTB + STB, Nismo Camshafts, Nismo Header w/o cat, Nismo Rims w/ BS RE-11 235/40/17. Plus some non-nismo stuff.. Parked next to a Stupid Neon
#9 | ||
geezinondowntheroad
#10 | ||
and what exactly is a CPS? the abbreviation of crank sensor is CKP, and for the cam sensor its CMP or (phase) depending on which cam sensor it is, but for the life of me ive never heard of a CPS, coolant position sensor maybe?
#11 | ||
geezinondowntheroad
I think CPS is like that saying "i could care less" which is used to mean that you don't care at all, which could be more accurately communicated by saying "i couldn't care less".
#12 | |
Carrrrrne asada
Whatever it's called. The stoopid sensor craps out. Here's how to replace it. . .
#13 | ||
just giving you a hard time, im in Nissan school right now so im a stickler for proper terms and shtuff.....
#14 |
what year does this recal go for...my car has been having long hard starts and i cant figure oout why...im not throwing any codes and everything checked fine...the starter battery alternator it was all good..this cps is the eonly thing i can figure out could cause it
#15 | ||
there is a fuel pump recall that the fuel pump is supposed to be upgraded for long cranks as well as the CKP
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Rate This Thread | |
