how to change a head gasket? - Nissan Sentra Forum - B15, B16 and B17 Sentra Forums
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average.
post #1 of 35 Old 02-04-2008, 09:58 AM Thread Starter
se-r2004
Quoted: 0 Post(s)
(Thread Starter)
anyone have a write up on here to change a head gasket?
Vib blue se-r...megan racing lowering springs...e/s motor mounts...DC sports header...Greddy catback...17 inch icw rims....2% limo tint
se-r2004 is offline
post #2 of 35 Old 02-04-2008, 10:56 AM
zsoker89
Quoted: 0 Post(s)
Send a message via AIM to zsoker89
Basically take everything apart until you get to the head, and swap the gaskets. Putting it back together is the really fun part.
S13 Redtop SR20DET [living life at 11 psi]
2004 Sentra 1.8s[/SIZE]
zsoker89 is offline
post #3 of 35 Old 02-04-2008, 11:09 AM Thread Starter
se-r2004
Quoted: 0 Post(s)
(Thread Starter)
yeah i was just wondering if anyone had pics on it....like how do i get the timing right?
se-r2004 is offline
post #4 of 35 Old 02-04-2008, 11:10 AM
orangelloSE-R
geezinondowntheroad
orangelloSE-R's Avatar
Quoted: 2 Post(s)
BigDave took a shot at it, apparently you have to be pretty careful lining things back up.
Can't find his thread, sorry.
2002 SE-R 5 speed
orangelloSE-R is offline
post #5 of 35 Old 02-04-2008, 11:14 AM
shanno575
shanno575's Avatar
Quoted: 0 Post(s)
Send a message via AIM to shanno575 Send a message via MSN to shanno575 Send a message via Yahoo to shanno575
something i probably wouldn't recommend doing yourself unless you're experienced with it
2001 Sentra SE with a po-tay-to
2003 Altima 2.5S
shanno575 is offline
post #6 of 35 Old 02-04-2008, 11:24 AM
specvmike
LEMONade
Quoted: 0 Post(s)
Send a message via AIM to specvmike
Yeah not a regular DIY project. A guy on here tried it himself having never done it before and lined the cam up wrong I believe. I think he ended up bending some valves. It will be a major undertaking and you should really have a mechanic check out your work as you are putting it back together.
EDIT: Here's his write-up: http://www.b15sentra.net/forums/show...ght=headgasket
2002 Blackout Spec V
specvmike is offline
post #7 of 35 Old 02-04-2008, 11:24 AM
seekerbeta
2.0 Sentra Lover
seekerbeta's Avatar
Quoted: 0 Post(s)
Send a message via MSN to seekerbeta
Ditto... and you have to machine/grind the block + Heads to make it flat before putting the new HG back... why do you think shops charge in excess of 600$ for a new one?... i recommend a HG Treatment... where they take the gasket out, and using tar and a few other things to make the break seal. usually about 200$ and good for about 10,000 Miles.
02 Nissan Sentra SER Spec-V || Stereo and Magnaflow Cat-Back
01 Nissan Sentra 2.0 (With PP)|| Brothers DD
seekerbeta is offline
post #8 of 35 Old 02-04-2008, 12:23 PM
tonymc
01 Sentra GXE Owner
Quoted: 0 Post(s)
I did mine 3000 miles ago. It cost me roughly 250 to get the head clean, resurfaced, valves adjusted.
Get the haynes manual. Make sure you have all the tools the say in the manual. And buy all new fluids and drain the ones in the car before taking it apart. Change out you water pump and thermostat as well as clean your Intake manifold an Idle air control valve. It helps trust me. Everything gets dirty.
I recommend getting some heavy duty zip ties to hold the timing chain on the pullys if you have never done it before.
I did mine myself and I tell you its not easy. Takes time and patience. Save 1000 dollars and get it done right at a family operated shop and not the stealership.
I have an 01 Sentra gxe by the way.
=Tonymc
tonymc is offline
post #9 of 35 Old 02-04-2008, 12:31 PM
shanno575
shanno575's Avatar
Quoted: 0 Post(s)
there's a haynes manual for the b15?
2003 Altima 2.5S
post #10 of 35 Old 02-04-2008, 12:57 PM Thread Starter
se-r2004
Quoted: 0 Post(s)
(Thread Starter)
i was just wonder cause im think either that is wrong or my fuel injector....the spark plug looks good work fine.....but i get a #3 cylinder misfire all i got left to go is the headgasket and the fuel injector...it idles and drives like total crap right now..any ideas?
se-r2004 is offline
post #11 of 35 Old 02-04-2008, 12:59 PM
shanno575
shanno575's Avatar
Quoted: 0 Post(s)
well have you done a leak down test to confirm it's your head gasket? are you missing coolant? is there coolant in your oil? does it overheat? if your car is acting up as bad as you say it is, i would guess there would be a lot more clues that it's your head gasket.
2003 Altima 2.5S
post #12 of 35 Old 02-04-2008, 12:59 PM
LowBudgetBaller
Quoted: 0 Post(s)
Send a message via AIM to LowBudgetBaller
If you ever overheated the motor, head/block must be milled.
If you're replacing w/a mls headgasket head/block should be milled though i have heard some people, not sentra owners, use a very fine grit sand paper on a small aluminum block and sanding down the surface lightly while spraying wd-40 to prep. Some use copper spray w/o milling the surfaces and just sanding. Can't say it won't leak but some found success.
If you never overheated and you plan to use just the oem composite gasket, you should be fine just to remove all previous gasket material w/a razor blade. I doubt milling is required.
Another tip, just as bigdave did, mark your chain/camgears/crankshaft w/a whiteout or something to make sure you're able to reinstall your chain properly. Once the chain is reinstalled, rotate the crank slowly by ratchet to confirm the valves and pistons clear. No need to disassemble your head unless you plan to change your valve seals too.
Good luck and keep us posted w/your progresss
LowBudgetBaller is offline
post #13 of 35 Old 02-04-2008, 01:34 PM Thread Starter
se-r2004
Quoted: 0 Post(s)
(Thread Starter)
whats a leak down test???....... car hasnt over heated stays how it always has.. i also marked the coolant tank to see if it does change no change yet..also no rust or anything on the spark plug.. gas mileage is like 16mpg though!
se-r2004 is offline
post #14 of 35 Old 02-04-2008, 01:34 PM
shanno575
shanno575's Avatar
Quoted: 0 Post(s)
have you checked your o2 sensors? known to cause crappy gas mileage if they're bad
2003 Altima 2.5S
post #15 of 35 Old 02-04-2008, 01:38 PM Thread Starter
se-r2004
Quoted: 0 Post(s)
(Thread Starter)
yeah i replace the maf and the first o2 sensor
se-r2004 is offline
User Tag List
