What kind of oil should I use? - Nissan Sentra Forum - B15, B16 and B17 Sentra Forums
post #1 of 25 Old 11-24-2007, 01:40 PM Thread Starter
dasfonzie
Quoted: 0 Post(s)
(Thread Starter)
I'm gonna change my oil today. It has full synthetic in it, so I'm gonna stay with that. But whatgrade should I use. I live near Cleveland so it's pretty cold.
2005 1.8s 5 Spd
dasfonzie is offline
post #2 of 25 Old 11-24-2007, 01:47 PM
RobSE
Quoted: 1 Post(s)
Send a message via AIM to RobSE
I use Mobile 1 Synthetic 5w30 on my 2.0 in Chicago.
2001 Sentra SE w/PP 5 Spd
2006 GTO 18s 6spd
RobSE is offline
post #3 of 25 Old 11-24-2007, 01:55 PM
seekerbeta
2.0 Sentra Lover
seekerbeta's Avatar
Quoted: 0 Post(s)
Send a message via MSN to seekerbeta
I use Mobile 1 Synthetic 5w30 on my 2.0 in Vancouver, BC, Canada.
02 Nissan Sentra SER Spec-V || Stereo and Magnaflow Cat-Back
01 Nissan Sentra 2.0 (With PP)|| Brothers DD
seekerbeta is offline
post #4 of 25 Old 11-24-2007, 02:33 PM
Konig01SE
Quoted: 0 Post(s)
I use Q Advanced Full Syntheic 5W30 in Newfoundland, Canada....5W30 would be your best bet.... 10W30 may be pushing it depending on how cold it would get there but either or should be fine.
2001 Nissan Sentra SE (2.0L SR20DE)
Intake, Stillen Header, XTD Stage 2 Clutch/Prolite Flywheel, Cherry Bomb Resonator/Borla Exhaust, Eibach Sportlines/KYB's, 18" Konig Hotswaps, Cross Drilled Rotors, SS Clutch Line, 6000K HID's, ES MMI's, Type S Front Lip/Toyota Corolla S Skirts/Type S Rear Lip
Konig01SE is offline
post #5 of 25 Old 11-24-2007, 02:52 PM
hcmiyata
Quoted: 0 Post(s)
Send a message via AIM to hcmiyata Send a message via MSN to hcmiyata
eneos ftw
'91 Toyota MR2 Turbo / 333.4 whp
RIP Turbo QG
DFW
hcmiyata is offline
post #6 of 25 Old 11-24-2007, 04:26 PM Thread Starter
dasfonzie
Quoted: 0 Post(s)
(Thread Starter)
i ended up goin with royal purple 5w30
2005 1.8s 5 Spd
post #7 of 25 Old 11-24-2007, 04:53 PM
SixthSpeed
PintoBeanSucksBalls
Quoted: 0 Post(s)
For a 1.8L 4-cyl engine, regular oil will do just fine. I use regular oil on my Spec V and it's been running smooth since I bought it.
SixthSpeed is offline
post #8 of 25 Old 11-24-2007, 08:04 PM
Moriya
Quoted: 0 Post(s)
I use Mobil 1 5w30 and have no problems with it.
Is Royal Purple really as good as its made out to be?
Where the hell can I find it? I never seen it at any autopart store in my area.
Originally Posted by Mykol
whats wrong with easy girls...i support them!
Moriya is offline
post #9 of 25 Old 11-24-2007, 08:19 PM
Strychnine
Quoted: 0 Post(s)
Why? Your car is not used for racing.
Pennzoil Platinum full synthetic is what I used now, before that was Amsoil.
2006 Spec V
Strychnine is offline
post #10 of 25 Old 11-24-2007, 08:53 PM
armadnigeneral
Quoted: 0 Post(s)
Send a message via AIM to armadnigeneral
No. It has the approximate shear stability of whipped cream sitting in the refrigerator...
Seriously, though. It has really poor shear stability. Pep Boys in my area sells it. I don't buy it.
Right now I'm using Castrol Syntec (not German ) 5W-30. Just changed after 3700 miles, and am now sending in my used Syntec to Blackstone. Most likely I'm starting a ~6000 mile run on it. Then I'll probably go for a Group IV synthetic till it's time for a high mileage formulation. Speaking of which, does anybody know anything about these "high mileage" oils? What I know is limited to the marketing angles (resists burnoff, minimizes leaks, etc).
2003 Spec V
Crashed, abused, loved. Damn thing just won't give up.
armadnigeneral is offline
post #11 of 25 Old 11-24-2007, 09:01 PM
pj311foo
Banned
Quoted: 0 Post(s)
From "Car and Driver"
More and more oil companies are coming out with "high mileage" oils now, some recommended for engines with as few as 75,000 miles on them. So what is a "high mileage" oil you ask? Well very generally speaking, these oils have two additives in them which are more suited to older engines. The first is normally a burnoff-inhibitor which helps prevent the oil from burning off if it gets past an engine seal into the combustion chamber. The second is a "seal conditioner", the exact makeup of which I'm not sure of, but it's designed to soak into seals such as head- and rocker-cover gaskets and force them to expand. Thus if one of the seals is a bit leaky, the seal conditioner will attempt to minimise the leak.
I've not had experience of high mileage oils myself, but a few people who've e-mailed me have passed on various tales from it being the miracle cure to it making no difference at all. I think the general rule-of-thumb though should be "if it 'aint broke, don't fix it." Just because your engine has over 75,000 miles on it, doesn't automatically mean you need high mileage oil. Is the exhaust sooty or smokey? Are you noticing oil leaks? Is the engine consuming oil? If your engine is working fine, the exhaust is clean and you're not noticing any problems, my guess is that it doesn't need high-mileage oil.
pj311foo is offline
post #12 of 25 Old 11-24-2007, 09:06 PM
Moriya
Quoted: 0 Post(s)
I saw that on this site:
http://www.carbibles.com/engineoil_bible.html
^ I am stealing that link from thevboard.
It had lots of info on oil, but TL;DR. (I will get to it...)
Moriya is offline
post #13 of 25 Old 11-24-2007, 09:12 PM
armadnigeneral
Quoted: 0 Post(s)
I read that website before. I'm kinda looking for a more in-depth explanation. Something BITOG-style. Or adc100 style...
2003 Spec V
post #14 of 25 Old 11-24-2007, 09:15 PM
SR20DE_MAN
Canyon junkie! ( ^o^) <3
SR20DE_MAN's Avatar
Quoted: 0 Post(s)
Send a message via AIM to SR20DE_MAN Send a message via MSN to SR20DE_MAN Send a message via Yahoo to SR20DE_MAN
Castrol Syntec 0W-30. Make sure the bottle reads Made in Germany on the back label. It must be 0W-30 & German made. If not, put it back on the shelf & buy some Mobil 1 instead. Heh!
Former 2000 Nissan Sentra SE owner. Now I drive a little & underpowered "girly" NA8C car that can own many big & overpowered "manly" cars on a good chunk of canyon roads & road courses. Go NA8C! \(^o^ ) <3
SR20DE_MAN is offline
post #15 of 25 Old 11-24-2007, 09:23 PM
Moriya
Quoted: 0 Post(s)
There's something else I can't find in my area.
Looks like I have to stick to Mobil 1...
Moriya is offline
User Tag List
