| Register | Home | Forum | Active Topics | Parts Catalog | FAQ | Photo Gallery | Search | Today's Posts | Mark Forums Read |
Thread Tools | Rate Thread |
#1 |
Hey i was just wondering if it was possible to disable the turn signal while the headlights were on except for actually signaling a turn i.e. blinking. The reason i ask is because i have luminics blue headlights and yellow fogs...rice i know...flame away...but it just looks weird/goofy with the turn signals on all the time...tried silverstars and clear..didnt like it. Any info would be appreciated...
02 SE-R, 5sp, fujita intake, strup/stillen H/E , ground wires, findanza ss, underground front lip |
| Sponsored Links | |
Advertisement |
#2 | |
I <3 Jackstands
Luminics ultra white headlights, piaa extreme white turns...dont match at all when im not actually using the turn signal, so it goes from blueish white in the headlights to f'in green in the turns, unless i flash them and then they match well.
2001 Granite GXE 5-Speed RIP 06/20/06-08/31/08 2000 Corolla 5 speed driven until i buy a 5.5 or 5 gen maxima on stick... ![]() www.team-driven.net: the family. |
#3 | |
Um, I could be wrong but I would imagine that amber colored corner lights are need to be present while the headlights are on (which normally signals dismal weather or night time)
But I'm honestly not sure, don't take me verbatim.
2001 GXE Autotragic ghetto grille, stillen hi-flow air intake, megan fstb, red signal overlays Quote:
#4 |
I <3 Jackstands
anyone have more info??
#5 |
SR20DE
how about a way to get them to stay on "hot" all the time, I mean at their brightes point so that the lights look much brighter and also a better color match.
Bulbs are two cycle, and the second one is the brightest when the signal is activated. Any wiring gurus want to put any input.?
SportE-B15 MY CAR My 85 El Camino 01 Blackout SE 5spd wP/P Weapon R header, VRS 2.5" catback, short ram intake w/K&N, 03 Spec-V Front end. 06 Spec-V wheels, 6,000k HID, Nismo LTB, Greedy trunk bar |
#6 | |
Moderator
2000 Heatwave Nissan Sentra SE w/ Performance Package
NISMo Suspension | NISMo 17x7.5 bronze wheels Alpine CDA-9835 HU | Kenwood KAC-9152d Amp | 12" Alpine Type-R Llumar 28%/38% Window Tint |
#7 |
If I am correct, all you would have to do is switch the "hot" wire with the parking light wire. And there your lights will burn brighter.
Why not just get your park lights to match your headlights? I personally, took off the orange in the bulbs and I just have clear bulbs now. When I have my signal on, the bulb still blinks a little orange from the side marker. |
#8 | |
I <3 Jackstands
If I were to switch the wire, wouldnt it end up being the same thing, as the bulbs are parking/turn?Diagram perhaps, as I really want to do this? Thank you, Ilya
#9 |
Well, if you look at your socket, it should be 3 wires. 2 hot wires and 1 ground wire. I'll go out and voltmeter it tomorrow, but technically if you switch those 2 hot wires, it should make the brighter end of the bulb shine instead of the dimmer end. I could be wrong, but in theory this should all be correct. Because if you put power to one side of the bulb, the brighter of the 2 lights should come on.
#10 | |
I <3 Jackstands
2001 Granite GXE 5-Speed RIP 06/20/06-08/31/08 2000 Corolla 5 speed driven until i buy a 5.5 or 5 gen maxima on stick... ![]() www.team-driven.net: the family. Last edited by blazingengine; 10-16-2006 at 12:18 AM. |
#11 |
I <3 Jackstands
bump for tomorrow
#12 |
I <3 Jackstands
owned by double post
#13 | |
SR20DE
It would shut off and blink when the turn signal was activated.
#14 | |
I <3 Jackstands
#15 | |
Moderator
| Thread Tools | |
| Rate This Thread | |
