Speaker sizes - B15sentra.net - Nissan Sentra Forum
Go Back   B15sentra.net - Nissan Sentra Forum > 2000-2006 B15 Nissan Sentra > Modifications - Audio
Old 10-14-2006, 06:22 PM   #1
Mofoka
Send a message via AIM to Mofoka Send a message via MSN to Mofoka
Speaker sizes
So I have a 2001 SE w/ PP.
I checked out cardomain.com and they said that the 2001 Sentra has 6.5" in the rear and 7" in the front. However, I don't think they factored in the PPif it makes a difference in speaker sizes.
Main question is, what sizes are the speakers in the front and the rear for a 2001 SE w/ PP?
Mofoka is offline   Reply With Quote
Old 10-14-2006, 06:34 PM   #2
Y2K SE
Moderator
Y2K SE's Avatar
Garage
Read the two stickies at the top of the Audio section. It has all the information about the audio system that you'll ever need. Basically, though, CarDomain is wrong, the speakers are 6.75".
Current:
2011 Navy Blue Metallic Nissan Altima 3.5SR Sedan
Previous:
2000 Heatwave Nissan Sentra SE w/ Performance Package | NISMo Suspension | NISMo 17x7.5 bronze wheels
Y2K SE is offline   Reply With Quote
Old 10-14-2006, 06:34 PM   #3
2001 SE #2
Send a message via AIM to 2001 SE #2
6.5-6.75 all around
Front are 2" deep but you can fit up to a .75" one piece spacer or 1" two piece spacer, giving yourself 2.75 or 3" depth respectively. The rear has around 2.25-2.5" depth before you hit the torsion bars.
'12 Grey WRX - the daily
'05 Silver WRX STi - the toy
'01 Sentra SE - the ready-to-sell
2001 SE #2 is offline   Reply With Quote
Old 10-15-2006, 03:10 PM   #4
Mofoka
I want to buy Infinity KAPPA speakers and they're 7" fronts and 6.5" rears. Here are the specs:
Fronts (Infinity KAPPA-652.7I)
Power Handling, RMS: 75 Watts
Power Handling, Peak: 225 Watts
Sensitivity: 94dB
Frequency Response: 45Hz - 25kz
Mounting Depth: 2-3/16"
Impedance: 2 Ohms
Rears (Infinity KAPPA 63.7I)
Sensitivity: 95dB
Frequency Response: 45Hz - 25kHz
Impedance: 2 Ohms
LMK if these will fit or if I'll need adapters/spacers, or anything else.
Old 10-15-2006, 03:19 PM   #5
2001 SE #2
They will fit, but the kappas don't sound very good and you'll also need an external amp to run them since the headunit can't handle 2ohm.
