Special Tool for Rear Brake Caliper Piston compression? - Nissan Sentra Forum - B15, B16 and B17 Sentra Forums
post #1 of 5 Old 09-03-2006, 03:54 PM Thread Starter
Z-Jay
Quoted: 0 Post(s)
Send a message via AIM to Z-Jay
(Thread Starter)
Hey guys,
When removing the brake calipers and replacing rotors & pads, I've seen reference to using a c-clamp for the front caliper to press the piston back in. But for the rear caliper, I've seen reference both here and in the service manual for a special tool that's used to press the rear caliper's piston back in.
What is this tool and can it be bought just about anywhere? Just looking for more detail on this special "tool".
Is getting this tool the ONLY way to get the rear caliper back on? (I just want to know before I take the calipers off the rotors and get stuck on this task at a point-of-no-return state).
Thanks!
Z-Jay
93 Onyx 300ZX TT, 5-spd, Stage VI+
01 Cajun Spice Sentra SE w/PP, 5-spd, AEM CAI, Nimso Lower Tie Bar, ZE-512's.
05 Majestic Blue Altima 3.5SE, 5-spd, stock (wife's)
Z-Jay is offline
post #2 of 5 Old 09-03-2006, 04:03 PM
Spec-Z
Quoted: 0 Post(s)
actually theytell you you need a special tool b/c the piston doesnt just push back in, you need to turn it counter clockwise (I think) or it to go back into the caliper. You can buy the special tool from auto parts stores usually. relatively cheap, or you can just use a pair of needle nose pliers and twist the piston back in using the tips. the special tool is much easier and much safer. The pliers method is harder and you might make the mistake of ripping the rubber boot if the pliers slip. then you're REALLY screwed.
my advice, just pick up the tool from the parts store.
*SOLD* OCT. 2010 - 2001 Sentra SE P/P Cloud White,ES MMI (removed), ES Shifter bushing, B&M SS, Tein Basics, 2nd gen. Mercury Sable front lip, Nismo RSB
Spec-Z is offline
post #3 of 5 Old 09-03-2006, 11:25 PM
AZ_2K_SE
I hide the bodies...
Quoted: 0 Post(s)
It's clockwise. Just did it-that's how I know.
You're about as useful as a jpg to Helen Keller.
2000 SE Auto w/PP--R.I.P.
AZ_2K_SE is offline
post #4 of 5 Old 09-04-2006, 08:56 PM
Octane
Vibrant Blue Army
Quoted: 0 Post(s)
I did it with the needle nose plyers, and it's was pretty easy, just be careful with the rubber boot like spec-z said
good luck!
'03 Vibrant Blue Spec-V - 35% tint - debadged - rusty HS cai - MM - custom SS - rusty doors sills
'02 Vibrant Blue Spec-V totaled by idiot chased by police after a hold up (member of the B15 graveyard!)
Octane is offline
post #5 of 5 Old 09-05-2006, 06:16 PM
AZ_2K_SE
Quoted: 0 Post(s)
I rented one from Checker, but I must have overdone the compressing part as I blew the seal. Now I get to rebuild it. Oh joy.
As for the dust boot, you definitely don't want to tear that. It keeps water out of the piston cylinder. If water gets in it can rust/corrode it mandating an all new calliper and piston. The cheapest one I've found is $121.
AZ_2K_SE is offline
User Tag List
