Easy to change a coil pack? - Nissan Sentra Forum - B15, B16 and B17 Sentra Forums
Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
post #1 of 12 Old 07-18-2006, 09:36 AM Thread Starter
Tofm
Quoted: 0 Post(s)
(Thread Starter)
My mechanic told me that my misfire problem is due to a bad coil pack. I heard that the part is pretty cheap so I'm thinking about just replacing it myself to save some green. Are there any instructions on how to replace it? Is it simple?
Tofm is offline
post #2 of 12 Old 07-18-2006, 09:48 AM
Ar6entino
Quoted: 0 Post(s)
more info about ur car would be helpful and what exactly is the car doing? any mods recently done?
2002 Blackout GXE *SOLD*
2009 Mazda3 Hatchback
Ar6entino is offline
post #3 of 12 Old 07-18-2006, 10:04 AM Thread Starter
Tofm
Quoted: 0 Post(s)
(Thread Starter)
2002 GXE, I'm getting a misfire (P0304) according to OBD. Car is completely stock. No smoke coming from exhaust.
Tofm is offline
post #4 of 12 Old 07-18-2006, 10:14 AM
Ar6entino
Quoted: 0 Post(s)
P0304 CYL 4 MISFIRE
Could also be headgasket but you have no smoke coming out, not sure. If the coil pack is cheap, you could try that.
post #5 of 12 Old 07-18-2006, 10:23 AM
once370lbs
Quoted: 0 Post(s)
Simple as pie. Just look it over and use good, common sense. Cylinder four is the one on the drivers side of the car. Get it fixed asap. You can overwork your cat and ruin it. Theres a small chance a bad injector will throw the same code. Change your oil after the fix to rid the engine of any fuel dilution.
I now weigh in at $1.74 @6'2".
once370lbs is offline
post #6 of 12 Old 07-18-2006, 10:34 AM Thread Starter
Tofm
Quoted: 0 Post(s)
(Thread Starter)
Perfect, thanks for the tips.
Tofm is offline
post #7 of 12 Old 07-18-2006, 01:21 PM
jcrow
Quoted: 0 Post(s)
Would it be easier it you just switch coil packs with another one of the cylinders and see if the code switches to the other cylinder? If the code switches to the other cylinder then you know it is the coil pack. Also pull the spark plug on 4 and see what it looks like.
03 GXE VIBRATE BLUE
k&N Drop In Filter / SS brake lines.
RIP DEC 2008
08 Versa SL
61,000
Sold
12 Rogue AWD
jcrow is offline
post #8 of 12 Old 07-18-2006, 01:26 PM
Ar6entino
Quoted: 0 Post(s)
Thats a great idea
post #9 of 12 Old 07-18-2006, 01:38 PM Thread Starter
Tofm
Quoted: 0 Post(s)
(Thread Starter)
I pulled the plug, other then a little soot it looked normal (Not dented or anything), although the other plugs were a little cleaner I'm guessing this is because of the misfiring? I haven't tried switching the packs, I will later tonight, thanks for the tip.
Tofm is offline
post #10 of 12 Old 07-18-2006, 09:50 PM
spectacle
Quoted: 0 Post(s)
Might be the injector, happend to me about 3 years ago.
spectacle is offline
post #11 of 12 Old 07-18-2006, 11:33 PM
GREEN01GXE
Quoted: 0 Post(s)
Send a message via AIM to GREEN01GXE
I had the same problem but it turned out to be Cyl 2.
Coil pack is easy as heck to replace , so definately do it yourself.
as once370 wrote, avoid driving it with the misfire because it WILL damage your cat. I was forced to drive about 60 miles with the misfire and now I've got a constant p0420 code (cat below efficiency threshold). The added raw fuel might also contribute to fouling of your O2 sensors which will cause additional problems.
my new coil pack cost about $65 I beleive.
Originally Posted by pilotenfs
.. the question is.. will the engine tough that bigger combustion?
GREEN01GXE is offline
post #12 of 12 Old 07-19-2006, 01:23 AM
3rdgearpull
Quoted: 0 Post(s)
I just ordered my coil pack .....it was 70 bux, plus another 80 for the valve cover i needed.....im installing them tomorrow. I had oil in my spark plug...couldnt even see the plug..did a nice tune up!
2003 Molten Silver Beast.....Lots of Go...no show!
http://i17.photobucket.com/albums/b5...re00533333.jpg
Far From Done!
3rdgearpull is offline
User Tag List
